Results 1 to 4 of 4
Thread: Multichannel support (VIA M1000)
    Sep 2006
    Perth, Australia
    Firstly, I want to say a huge thanks to you and the community. You guys have created an awesome program, and it's only getting better
    I'm not sure if this is a bug that I've found, or if it's a limitation, or no-one has asked and therefore isn't done...
    I want to be able to adjust the volume of my rear speakers and sub..
    Before you jump to conclusions... the faders aren't on the playback panel of windows volume control... they're on the "other" tab... multi-channel...
    I've attached a pic for clarity...
    Is there any way to adjust the volume of these sliders within rr?
    Cheers
    -Travis
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There are command and slider codes that you can specify the audio line BY NAME, if those don't work, then you're out of luck.
    Ride Runner RR's Myspace
    Sep 2006
    Perth, Australia
    looks like I'm out of luck then.... what a shame
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there's plenty of people here that have been able to use the built in center-rear volume control from EPIA boards using the same functions, if you post a debug log, I can try to help further, otherwise I have nothing to go on.
  1. Tech Support Calls
    By Rafster in forum Off Topic
    Last Post: 06-12-2006, 11:49 AM
  2. RR 08-02-05... SIRIUS Support ...
    By guino in forum Road Runner
    Last Post: 03-09-2006, 01:44 PM
  3. RR 08-30-05 ... Ipod Support & Fixes ...
    Last Post: 09-09-2005, 05:50 AM
  4. RR 06-06-05 .. Winamp Library Support ...
    Last Post: 06-19-2005, 12:36 AM
  5. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 10:37 PM
