Results 1 to 6 of 6
Thread: Freezing on startup.
    Dec 2006
    Unhappy Freezing on startup.
    i am using the 11/12/06 version of roadrunner installed with webmasters installer. This is sitting on a windows 2000 pro with via MII-12000 motherboard. When i start roadrunner it sits there saying starting winamp.
    I checked the task manager and rr is running at 99%. winamp is started. i unchecked "hide winamp" in rrconfig so i could be sure it was starting up (i am using winamp 2.95). I have left this running all night and it is still at the same screen. i have to kill the rr process then kill and restart explorer. has anyone any ideas what is causing this. I have phonecontrol, windvd, mediaplayer classic, map monkey & freedrive, d-link usb fm radio installed. All of these work when run on there own.
    If some one could help i would appreciate it. thanks.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Just a thought, but as you are using windows 2000, you may need to update your VBRuntime files. I am not even certain if this is the problem or not, but it's one thing to rule out if it's not.
    My Fiero Build Thread
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Follow the High CPU/Unresponsive Buttons/Flash issues faq and try again. Some machines just freeze when Flash is completely missing.
    Ride Runner RR's Myspace
    Jan 2005
    Phoenix, AZ
    Hmm, I'm having the same issues. I updated to XP SP2 and now RR won't go past "Starting Winamp". Happens even on a completely clean RR install. Does RR keep a log somewhere so I can get a better idea of exactly what it is hanging on?
    Edit: Found debugmode, nothing useful from my perspective though :-/
    I've tried with flash player installed, and without. With Winamp installed, and without. I don't have phoco installed or configured. I'm not sure where to go from here :-/ RR gets to the point below, then ramps the CPU up to 100% and stops there.
    Code:
    12/16/2006 1:59:55 AM: Start -- Version: 5/2/2006
    12/16/2006 1:59:55 AM: Master Vol: Speaker/4
    12/16/2006 1:59:55 AM: GetLineControl Failed: 401
    12/16/2006 1:59:55 AM: No Treble Support
    12/16/2006 1:59:55 AM: No Bass Support
    12/16/2006 1:59:55 AM: No Master Mute
    12/16/2006 1:59:55 AM: No Master ON/OFF
    12/16/2006 1:59:55 AM: Source: Wave=&H1008/1
    12/16/2006 1:59:55 AM: Source: SW Synth=&H1004/2
    12/16/2006 1:59:55 AM: Source: CD Player=&H1005/3
    12/16/2006 1:59:55 AM: Winamp window not found.
    12/16/2006 1:59:56 AM: Shell: "C:\Program Files\Winamp\winamp.exe"
    12/16/2006 1:59:57 AM: Sim.WMSGs: 1
    1998 BMW M3
    Mods: Staggered SSR Competition wheels : M Roadster Short Shifter : JTD Aluminum Underpanel : Koni Adjustable SAs : Eibach Pro-kit springs : European clear corners and side markers : Hardwired V1 automatic door and radar detector
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    I did a fresh install of windows xp - installed the new-est road runner,
    worked with my old skin, tried the CrystalBlue_Skin and the clock looked
    funky, so I used the flash uninstaller, and downloaded the new flash and installed, now it just locks up,
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Did you guys follow the Flash FAQ on trying to fix the issue ?
  1. Auto volume on startup
    By stric in forum CF Plugins
    Last Post: 03-05-2007, 05:43 PM
  2. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  3. XM as startup command
    By skippy76 in forum RR Bug Tracker
    Last Post: 10-07-2005, 07:01 PM
  4. Startup is too fast!!!
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 02-05-2005, 11:20 PM
  5. Windows freezing
    By vipergda in forum General Hardware Discussion
    Last Post: 11-13-2004, 02:51 PM
