Results 1 to 5 of 5
Thread: (IDL) Idle Timer Bugs
    May 2005
    I am trying to close the confirm delete prompt in my CONFIRM.SKIN if there are no response within 5 secs. Here is what I have done.
    In my CONFIRM.SKIN, I added:
    IDL,5
    In ExecTBL.ini, I added:
    "IDLE","EXIT",Confirm.skin
    When I press the DELETE button in my Audio_Browser.skin, it calls up the Confirm.skin. If there are no mouse/keyboard actions within 5 secs, it closes the skin as expected. That's the good part, now comes the bad part...
    Error #1:
    After it auto exit the confirm.skin, if I were to press the DELETE button again which in turns calls the confirm.skin again, it doesn't exit the skin the 2nd time round after 5 secs of inactivity from the mouse/keyboard. In other words, it only works the 1st time.
    Error #2:
    According to the skin command.txt, it states:
    /, (IDL) Idle Timer
    /, Seconds
    IDL,XXX
    The above defines the number of seconds in "IDLE" state (no mouse/keyboard actions) to
    execute the "IDLE" event that can be defined in ExecTBL.INI so a command is executed at such time.
    However, I found that the IDLE event only works if you do not click the mouse button. Moving the mouse cursor or pressing the keyboard does not prevent the IDLE event from kicking in which is suppose to do so according to the instructions.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I use the TIMER event. Same thing then IDLE but works every time.
    TMR,5
    in the confirm skin and
    "TIMER","EXIT",confirm.skin
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I know that this is an old thread but this bug is still active.
    Just gave the thread a little bump so it can eventually get fixed.
    The road is long but we are getting there.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll take a look at this today.
    Ride Runner RR's Myspace
    guino's Avatar
    Nov 2004
    Toronto, Canada
    fixed.
  1. 12 Volt Timer For Computer
    By kozmo in forum Power Supplies
    Last Post: 02-18-2007, 11:02 AM
  2. Replies: 19
    Last Post: 07-27-2006, 04:44 AM
  3. Timer Circuit
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-04-2005, 10:47 AM
  4. Replies: 0
    Last Post: 06-14-2005, 11:46 PM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
