I'll add the prevention, Thanks man.
Guino,
When using multiple extensions plugins and using a custom Slider the slider does not work when is sits in the first extension plugin that was loaded.
Bug is in function UpdateSliders
Fixed it like this:
'Check extension plugin for Slider value
For t = 1 To UBound(Ext)
If (Ext(t).ReturnSlider(SLDCODE) > 0) Then Value = Ext(t).ReturnSlider(SLDCODE)
Next t
Added red part
So the Value will only be set is there is a value found > 0. Value was getting reset by the second plugin which does not have the same slider.
My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
Hardware: None at the moment
Software: None at the moment
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 0 % DONE
Ride Runner RR's Myspace
Did you already add it. I downloaded the latest beta and I noticed my sliders stopped working again.
This is what the new code is right now. Idealistically ReturnSlider should return -1 for sliders not processed in the plugin, but I'm afraid I may have to remove the = 0 from there for the plugins that are old
Code:'Check extension plugin for Slider value For t = 1 To UBound(Ext) 'TotalSecs is just a holder so we only ask the plugin once TotalSecs = Ext(t).ReturnSlider(SLDCODE) 'If we received an acceptable value, then we use it If TotalSecs >= 0 Then Value = TotalSecs Next t
