Results 1 to 9 of 9
Thread: Button Focus Problem
    Mar 2004
    I'm running RR from 11-12-06 and LSXVoid 2.02
    I have an issue that if I switch to SAT, and sometimes NAV or AUDIO, when I come back to the main screen the SAT button is highlighted. The highlight will go off if I touch another button on the screen.. Any idea why this could be happening? Is this a bug??
    I posted in the LSXVoid thread and it was mentioned that the cursor is not going to where its supposed and its hovering over the SAT button..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    probably the button you pressed to exit from the previous screen got the mouse over to that location and thus highlights it. You can disable the highlights altogether by changing the ON screen in the .skin file to be the same as the OFF screen. There is no current way to "hide" the highlight, but it could be added.
    Ride Runner RR's Myspace
    Mar 2004
    Quote Originally Posted by guino View Post
    So, if I were to disable the highlights in the .skin, I would get no feedback as to what button I push (except for when the application loads, obviously).. Right?
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    So,
    no highlights at all or live with it.
    Am I getting that right?
    Would be nice to have a way of it not highlighting unless the mouse was pressed but not hovering over the current button.............
    But that's way above my current ability.
    Leonardo Da Vinci
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    You could just change the "ON" graphic file to remove that specific button highlight. At least, you can keep all the other exect that particular one.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    No need to change any graphic files, just use OFF,OFF,OFF,DOWN images and you have no ON stage.
    May 2007
    Quote Originally Posted by MGD View Post
    Pardon my lack of knowledge, but I don't follow you..........
    Leonardo Da Vinci
    Aug 2006
    Sun Diego
    Quote Originally Posted by greatwhite View Post
    For example, at the top of the skin file, there should be lines, that look something like this:
    Code:
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    Change to:
    Code:
    MEDIACAR Skin
    May 2007
    hmm, thanks.
    I'll have a try!
    For some reason, I can understand it when someone points this stuff out, I just can't seem to figure it out on my own yet.
    Cheers
    BJ
    Leonardo Da Vinci
  1. Button request: Minimize
    By DaveB in forum Mobile Impact
    Last Post: 01-04-2007, 09:35 PM
  2. BMW iBus problem - Not detecting Button Pressed
    By captain_jim1 in forum Software & Software Development
    Last Post: 06-14-2006, 04:10 PM
  3. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Replies: 2
    Last Post: 04-04-2005, 04:45 PM
