Results 1 to 8 of 8
Thread: volume gets muted when changing song
    Jan 2007
    For some reason all of a sudden when changing a song or when a song ends and it goes to the next the sound guts turned all the way down? Also for some reason the name of the song does not chance until you move out of the screen and back into it.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by benblank04 View Post
    What version of WinAmp are you running?
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Quote Originally Posted by 2k1Toaster View Post
    I am running v2.95, my volume issue turned out to be because the volume in winamp was turned down so everytime the song changed the volume when back down to where it was set in winamp.
    So now I have to figure out why the does not update the name of the current song that is playing.
    Sep 2006
    Richmond, Tx: USA
    I started experiencing the same problem today. Everything was working fine uptil now but now everytime I change the song volume gets muted.
    Feb 2004
    Paducah, KY
    Yeah, opening winamp outside of RR and pushing the volume all the way up seems to fix it for a while. But something is triggering this problem to reoccur from time to time, and I can't seem to pin down what it is.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Run RRConfig, goto General page 2, look at what Map Master Volume to Control Line.
    Try it on Master or Wave, or just experiment to see if it makes it better.
    Feb 2004
    Paducah, KY
    will do. Thanks.
  1. Multiple Soundcards - Volume Control...
    By Jarrod in forum Road Runner
    Last Post: 07-17-2006, 01:25 PM
  2. Request: Winamp volume
    By froop in forum Road Runner
    Last Post: 06-07-2006, 03:04 AM
  3. Winamp volume problems
    Last Post: 09-17-2005, 12:02 PM
  4. Changing song highlight colour
    By mindracing in forum CF Skins
    Last Post: 08-18-2005, 02:45 AM
  5. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
