Results 1 to 10 of 10
Thread: Album Art Woes
    Jun 2006
    Album Art Woes
    Hello All,
    I am having some issues and was hoping somebody could help.
    First of all, Album Art. I posted this question in another thread also and I have tried their suggestions. I made sure the folder.jpg file is located in the root folder and sub directories of a particular album. I made sure that the file is unhidden, as windows hides automatically. Streetdeck and Windows media player displays the art without any problems. I made sure the music directory is correct in the RR Config. But even, after all this, I still do not see the art in the skin. I also tried other skins and same issue. Maybe its a issue with RR in general. But I do not know what else to look for, everything seems normal.
    Can anyone please give me a few suggestions. I forgot my other question at the moment, will ask later.
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    What skin are you using?
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    Jun 2006
    Current skin
    I am currently using the simplistique skin, but have also experienced this with the digitalfx skin.
    thanks
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Album Art
    It sounds like you have everything set correctly. It is definately not a Road Runner problem in general. The album art works fine here in the DigitalFX skin, and the other skins I have tried, so its a matter of narrowing it down.
    You have the jpg's in the right place, you have unhidden them, so only one other thing comes to mind.
    Open the Road Runner Config utility, and click on the music tab. Where it says "Album Cover File" make sure the box contains *.jpg
    Thats the only thing I can possibly think of at the moment, as it does work in other programs, so we know the images are in the right place.
    My Fiero Build Thread
    Jun 2006
    Still having issues
    Well I have checked to make sure album cover files is set to *.jpg and I have double checked everything else also.
    I think I will completely remove my music collection, it was originally created using MusicMatch. I will try ripping a album using winamp and then windows media and see what happens.
    I dont think that should make a difference, but who knows.
    If anyone has any other suggestions meanwhile, please let me know.
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Do you have actual jpegs for the album in the album folder?
    It sounds like your trying to see the embedded art that WMP and StreetDeck (uses skinned WMP) show.
    In order to display the embedded art in RR you need to download and install the plugin found in this thread = Embbeded Mp3 Art Plugin
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Jun 2006
    How do I install
    Thanks for the info, but how do I install the plugin?
    I have downloaded it.
    Here are the instructions:
    "INSTALL
    1-Copy MP3ART.DLL to install location (of your choice -- DO NOT MOVE IT AFTER STEP 2!)
    2-Regsvr32 MP3ART.DLL
    3-Add: X,Mp3Art to menu.skin of desired skin"
    So I understand step 1, according to that, lets say I copy the dll file to the RR directory, but then what do I do in step 2 and 3?
    Is "Regsvr32" some type of code that I have to input somewhere?
    And then step 3 says to add. I am assuming that means to open menu.skin file in say notepad and add it there. So do I type in the following w/o quotations? "X,mp3art" ? If so, is that at the end of the whole code right before end?
    Sorry for the specific questions, but I am not a programmer.
    Any info would help thanks
    Nov 2005
    Midlands
    Hi,to be honest i don't use this plugin however it should be easy to install.
    To register the DLL you need to run Regsvr32 (this is a windows app)
    Move your DLL to where you want it (RR's folder or system 32)
    Now open the start menu and select the RUN box.
    To install the file,type: regsvr32 MP3ART.DLL and then hit enter and you should get a confimation that the DLL has been registered.
    If you have any trouble with this see this link = http://www.free-codecs.com/guides/Ho...d_AX_files.htm
    Guino already explains the 3 steps pretty well in this thread = Embbeded Mp3 Art Plugin
    PLEASE NOTE: What isn't clear in guino's post is this part = "X,Mp3Art to menu.skin of desired skin"
    What he should of said is add "X,Mp3Art" to the skin that you want to see the art on,this is more likely to be audioplayer.skin than menu.skin.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Griff1 View Post
    NO, DON'T do that.
    open the MENU.SKIN file, and towards the top, on a blank line put:
    Code:
    "X,Mp3Art
    This is the trigger for Road Runner to load the plugin when a skin loads. As the first screen that loads when RR loads, is the MENU.skin file this was a likely choice for Road Runner to look for any helper skins. ALL plugins should ALWAYS be placed in the Menu.skin file.
    Nov 2005
    Midlands
    Thanks John,I stand corrected.
    I don't use this plugin but i was tryin to help,whoops.
    Ya learn something new every day : )
  1. Album Art for StreetDeck
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 05-31-2008, 05:16 PM
  2. More on Album Art (bug/feature request)
    By unlfrank in forum Freeway
    Last Post: 12-28-2006, 12:58 PM
  3. Album art downloader
    By hijinks21 in forum Software & Software Development
    Last Post: 07-20-2006, 10:56 AM
  4. Replies: 18
    Last Post: 03-12-2006, 06:56 PM
  5. Select album to play via album art
    By xGumbyx in forum Mobile Impact
    Last Post: 01-25-2006, 08:46 PM
