Results 1 to 5 of 5
Thread: ComSend not working in first screen
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Hi Guino,
    I'm trying to send commands to Road Runner using COMSend "RoadRunner", Command from a extension plugin. This is working but only after I have once switched to another screen. So, when I start Road Runner it will not accept commands (even when I pressed buttons) but Road Runner starts to accept commands after I have switched to another screen. It will then work on my menu.skin as well.
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should not use Comsend from an extension plugin -- it will basically make a recursive call to your own extension plugin. Instead, you should return processcommand = 3 with the new command to execute in CMD. There's a note about that in the header of the extension plugin sources.
    Ride Runner RR's Myspace
    Apr 2005
    The Netherlands
    I'm not executing a comsend based on a command button in the extension plugin. The plugin (timer) checks the state of hardware buttons of my k8055 usb io board. I have assigned RR commands to these hardware buttons that will need to be executed from the extension plugin in RR. I'm using comsend for this. So this not be recursive. The problem I have occurs only when I start RR and have not switched to another screen. After switching to another screen everything is working correctly. If have been debuggin my code but it is working and the Comsend does not return an error but RR never executes the command.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If it works on one screen, it should work on all of them.. that's weird, unless there are other windows opened with the same name (thus the messages could be going to the wrong window).
    Have you tried the COM method ?
    Dim SDK as Object
    Set SDK = CreateObject("RoadRunner.SDK")
    then
    SDK.Execute "COMMAND"
    You'd do away with a bunch of code and it's a lot cleaner too -- check below for details.
    http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
    Apr 2005
    The Netherlands
    OK, I'll try switching to your SDK example.
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 06:06 AM
  2. USB TOuch Screen not working after install?
    By belezeebub in forum Input Devices
    Last Post: 10-01-2006, 02:14 PM
  3. Dynamix touch screen not working after standby (S3)
    By mrloofer in forum LCD/Display
    Last Post: 05-10-2006, 02:04 PM
  4. Winamp Vizs not working with Lilliput screen
    By d1g1tal3nvy in forum Media Engine
    Last Post: 04-19-2004, 04:59 PM
  5. DennisK Microtouch contoller and screen working.
    By LESLIEx317537 in forum LCD/Display
    Last Post: 03-22-2002, 07:46 AM
