Results 11 to 20 of 28
Thread: When starting Iguidance, sometimes desktop show instead
  1. #11
  2. #12
    May 2006
    Calgary, Alberta
    Quote Originally Posted by treetop777 View Post
    Put "/,(space)" (without quotes) in front of the "C" lines and add ignative=true to rr.ini..It'll work perfect everytime..
    Didn't work. I tried every combination of the following:
    1. added ignative=true to rr.ini
    2. added /, before the C line in external_gps_small.skin
    3. added /, before the C line in external_gps.skin
    4. changed the GPS path to IGLaunch.exe|nowarning instead of iguidance.exe|nowarning
    5. ran roadrunner.exe instead of rr.exe
    I was at it for over an hour, nothing changed. It still works exactly the same as it has since the first day I installed it all over a year ago. Nobody's been able to help me fix it.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #13
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Enforcer View Post
    pics don't show.
    Still? I need to know if people can see them so I can find out if there's something up with my server.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  4. #14
    May 2006
    Calgary, Alberta
    So my DNS registration expired last night, super. Pictures will return once I get it sorted out.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Maheriano View Post
    Your domain name has been jacked,, probably expired.
  6. #16
    May 2006
    Calgary, Alberta
    Ya, expired. Fixed now.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  7. #17
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, looking at those pictures, the problem is the GPS receiver is not connected warning, that is what is initially getting 'captured' by rr, then when you close it and re enter it captures the correct window.
    Make sure you have not set up the comport that your GPS is connected to in RRConfig.
    There may also be a setting somewhere where you can disable the no GPS warning.
  8. #18
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    You're almost there: in menu.skin, make the B21 line exactly like this:
    B21,29,189,144,147,"LOAD;External_Gps_Small.skin;i Guidance;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance",
    In RRConfig make sure the External GPS path is pointing to iGuidance and the window name is correct.
    Leave the "/, " and ignative=true
    Fire it up and you will get this; still with warning but that would go away if you give it a GPS signal.
  9. #19
    May 2006
    Calgary, Alberta
    Not set up the com port? You mean go into rrconfig and leave that space blank? I have the GPS receiver set up on port 4 (or 3?) but split it with xport so that it goes to port 6 instead and that's what I have in rrconfig, the virtual port. Then I split it to port 5 as well and I use that virtual port for iGuidance. It might be the other way around but you get the idea. So are you saying to go into rrconfig and don't specify a port?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  10. #20
    May 2006
    Calgary, Alberta
    Going to go try this now!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. BR-355 and iGuidance
    By DookieGraphics in forum GPS
    Last Post: 09-10-2008, 10:14 AM
  2. iGuidance not remembering com port
    By nkotch in forum GPS
    Last Post: 08-18-2006, 05:20 PM
  3. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  4. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 06:25 PM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
