Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 100 of 107
Thread: How to Embed any GPS program into Road Runner
  1. #91
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    I was using iGuidance 4.0 (iGuidance no longer supported/available) and iGo8 but the maps are so out of date so I have switched to PC Navigator 12 and this seems to be the latest that looks good. Some people have Sygic but have not found the USA version available. GPS Software for PCs are becoming harder to find.
    Gee
  2. #92
    Sep 2012
    Germany - Munich
  3. #93
    Mar 2011
    igo 8 with "igo-mysize" does not resize.
  4. #94
    Jan 2006
    Dublin, Ireland
    I have iGO ver 831 which I think is not possible to resize anymore. I think only iGO8 was possible for this. What GPS would people recommend for use with RideRunner Reborn skin ?
  5. #95
    FLAC mauri's Avatar
    Jan 2004
    I did a quick and easy exe with Autohotkey... try if it works .
    edit:
    ONLY for Igo skin 800 x 480
    Attached Files Attached Files
  6. #96
    Jan 2006
    Dublin, Ireland
    Thanks for that. However, two problems
    1. The window made by the wrap seems too small. It is cutting the bottom of the screen
    2. the Wrap program is loading on top of the Skin. Can someone please advise me as to what changes I need to make to my igo8.skin file ?
    Code:
    RideRunner Skin
    RRScreen "IGO8"
    INC,COLOR.txt
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,93,527,25,15,"MUTE:b"
    I02,553,536,30,42,"STATUS"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,25,20,80,16,#COLOR#,10,"Arial Narrow:B","BYIND;ONLINE;=OFFLINE<<=ONLINE","CENTER"
    L02,695,20,80,16,#COLOR#,10,"Arial Narrow:B","BYIND;GPSVALID;=SEARCHING...<<=GPS FIX","CENTER"
    L03,695,37,80,16,#COLOR#,10,"Arial Narrow:B","GPSSAT||=  SATS","CENTER"
    L04,124,26,554,22,#COLOR#,20,"Ericsson GA628","TRACKNAME>>TAGTITLE","SCROLL-CENTER"
    L05,205,546,122,21,#COLOR#,20,"Ericsson GA628","=VOLUME:","RIGHT"
    L06,331,546,70,21,#COLOR#,20,"Ericsson GA628","VOLUME","LEFT"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,690,16,90,40,"LOAD;GAUGES.skin",""
    B02,7,520,58,74,"VOL-",""
    B03,67,520,58,74,"MUTE",""
    B04,127,520,58,74,"VOL+",""
    B05,418,520,58,74,"PREV",""
    B06,478,520,58,74,"STOP",""
    B07,538,520,58,74,"PLAY",""
    B08,598,520,58,74,"NEXT",""
    B09,667,520,58,74,"CLOSE",""
    B10,736,520,58,74,"EXIT",""
    /, A, x, y, w, h, color R;RGB, G, B
    AX01,0,65,800,450,"OPT_NOFOCUS"
    NG,0,65,800,450
    END
  7. #97
    FLAC mauri's Avatar
    Jan 2004
    The wrap can make Igo open in any position desired X or Y, just edit "Settings.ini", read the "Readme" file ...
    If you want to do instead of resize Igo than 800 x 480, you can not.
    Igo reads the data of his skin for the resolution, and you can not do a resize at will while keeping a look proportional.
    If you are using a different resolution from 800 x 480, for example less, would cut the skin of Igo according to resize as you want.
    Edit:
    i have only test the wrap in stand alone mode, not with RR...
  8. #98
    Jan 2006
    Dublin, Ireland
    This is what I get now. It is chopping smaller than 800 x 480. And at the top, you will see why I want to put it behind the skin
  9. #99
    FLAC mauri's Avatar
    Jan 2004
    Try this:
    Copy in "sys_pc.txt" (Igo main folder) this code, and NOT use (if work well) my wrap:
    [rawdisplay]
    class="landscape"
    border=0 ; ---> this remove the top border of Igo window
    highres=0 ; ---> ok this value for use 800 x 480 skin
    screen_x=800 ; ----> X dimension of skin
    screen_y=480 ; ----> Y dimension of skin
    posx=0 ; ---> set you X position (in px) of left top corner
    posy=0 ; ---> set you Y position (in px) of left top corner
  10. #100
    Jan 2006
    Dublin, Ireland
    I don't know what happened before but it seems much better now. It seems to have stopped chopping the bottom away. And the Border=0 makes it perfect
    I am also playing with screen_y=460 and this is also producing good results too
    Many thanks. I'll let you know by the weekend as to which version works best and I will include a screenshot of the finished result.
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 05:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 04:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
