Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 86
Thread: How to Embed any GPS program into Road Runner
  1. #21
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    What is there is correct, but what version of sygic drive are you using?
    What skin are you using?
    As long as you have entered the gps and path correct it will work, thats exactly what i use on mine.
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #22
    Aug 2007
    Looks like its the skin thats stopping it, i was using "simplistique" skin, when i went back to the default bmv2, it worked like you said it would, apologese..
    Regards
    Ric
  3. #23
    Newbie k1hog's Avatar
    Oct 2007
    Can someone provide the info for Co Pilot, a good program for RV'ers.
    Johnnie
  4. #24
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    Angry
    need help with mappoint 06
    i just installed RR and using default skin w/ GPS windo name set to mappoint.
    When I click on gps button nothing happens however mappoint does start as eternal gps if i select external options...
    does any one know why map point doesnt want to load w/ the skin?
    tnx!
  5. #25
    Sep 2008
    Okay I found my navigator6.... and did what you said... and it opens... but it takes over the screen... either that or arent squized into the skin...
  6. #26
    Oct 2008
    I'm having the same issues... None of the buttons work, and Mappoint just runs normally like it would in windows. I'm using Mappoint 06 on XP btw
  7. #27
    Nov 2006
    Wales, UK
    Quote Originally Posted by Jammerlabz View Post
    Version 6 of PC Navigator does not support any window re-sizing, it is designed to run stand alone only. When Navigator 7 was released, a patch was released (following forum members requesting it, if I do recall) to allow the window to be re-sized correctly by RR.
    Quote Originally Posted by snoopbiscuit View Post
    Have never used map point I'm afraid. I would advise you to search for a program called Win Spector, which will allow you to get the program info to allow it to be embedded into RR correctly.
    These are the details other members are using, unless I typed them in wrong, can anyone else confirm these settings are ok with Map Point?
    MapPoint
    Product Home Page:
    http://www.microsoft.com/mappoint/pr...6/default.mspx
    Embedding Details:
    GPS Path:C:\Program Files\Microsoft Mappoint\Mappoint.exe
    GPS Window Name: Mappoint
    CarPuter Progress:
  8. #28
    Oct 2008
    hi all....
    1. i tried GARMIN setting (DFX4, mode "MENU", path:c\garminmobilepc\que.exe, gps name:GARMIN MOBILE PC), did'nt launch GARMIN apps (just RR background). When i run RR Garmin (overlay skin version) first, then press GARMIN (DFX4), thats all work....
    need help, why i can't launch GARMIN by RR config?
    2. how to set "GAUGES" (satellites, speed, compass) to make full functioning for GARMIN?
    phanaka
    ROADRUNNER....HARD begin,COOL end
  9. #29
    Jul 2008
    Lockerbie Scotland
    MapPoint 2009 Europe edition
    Gps path : - X:\Program Files\Microsoft MapPoint Europe 2009\MapPoint.exe
    Gps Windows Name - Map - Microsoft MapPoint Europe
    Change the X to your drive
    Not sure how the us version works, but the euro one opens in another window then loads into RR as well
    Prob 60% complete
  10. #30
    Nov 2006
    Wales, UK
    Post #1 Updated
    CarPuter Progress:
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 05:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 04:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
