Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 86
Thread: How to Embed any GPS program into Road Runner
  1. #31
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    everything you need to get Garmin MobilePC working with RR is in this thread:
    http://www.mp3car.com/vbulletin/rr-s...1-09-08-a.html
  2. #32
    Newbie 7volumes's Avatar
    Nov 2007
    Hi all, how about iGo 8 ?? how can i embedd it to road runner ?? does anyone know? It seems i'm not beeing able to do that, and when it runs if i want to return to road runner it automatically pops up again (iGo)over any menus i'm on. Any ideas?
    Regards,
    Ricardo.
  3. #33
    Nov 2007
    Hi, thanx for all that info but i'm having a problem with iGo8, not embedding but making him stay in the background when i wish to return to the FE menu... It keeps poping up the GPS image over the Roadrunner menus (even if i change skins )!! Could someone help me with that??
    Regards,
    Ricardo
  4. #34
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by 7volumes View Post
    Regards,
    Ricardo
    Post your button command.
  5. #35
    Nov 2007
    Quote Originally Posted by treetop777 View Post
    My button command?? do you mean the GPS Path and GPS window namein RR config?
    Path: C:\IGO8_PC_30-09-2008\igostarter.exe
    Hope that's what you need...
    Thx for the help treetop777,
    Regards
  6. #36
    Sep 2006
    War-Town, GA.
    Regards
    Try changing the window name to "IGO8" (without quotes)
  7. #37
    Nov 2007
    No luck on that.. still pops up when i try to go back on RR menus ! Any other suggestions treetop777?
    And by the way, ty for the quick replys
  8. #38
    Nov 2007
    Snooping around skin files i found this on ExecTBL.ini :
    /IG2 START
    /IG2.1
    /path to GPS............................................... .......{ path to your gps application }{ window title}
    "GPS1","GPS||RUN;LSTOOLS\SB2.9\iGuidance\IGCONTROL.exe"
    /....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
    "GPSFS1","LOAD;EXTERNAL_GPS_FS.skin;RUN;;iGuidance||RUN;LSTOOLS\SCRIPTS\EXIT_FS.exe"
    /this command is used only on External_GPS.skin, close button on bottom left
    /"EXIT2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe||EXIT"
    /"LASTSCR2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe||LASTSCR"
    "IG2MENU","RUN;LSTOOLS\SCRIPTS\torch.exe"
    Could this be the problem?? If so how can i change this in order to make the GPS stops popping?
    Thx,
    Ricardo
  9. #39
    Sep 2006
    War-Town, GA.
    Yeah, LSX Void doesn't lend itself to chages very easily and those commands are intended for Iguidance.
    Check PM and report back
  10. #40
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    try GPS as the launch button cmd on main menu or where your gps launch button is.
    B,xx,xx,xx,xx,"GPS"
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 05:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 04:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
