Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 107
Thread: How to Embed any GPS program into Road Runner
  1. #51
    Aug 2004
    Germany
    What he said. You can't have multiple programs use the same gps port. Use a com port splitter like xport. Running fine on my carpc.
  2. #52
    Jun 2009
    Hi thanks,
    In fact after I posted here I found xport, it works great.
  3. #53
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    any chance we could get a few helpful hints on Street Atlas 09/10 it integrates fine as far as screens are concerned just need to learn how to make the buttons work...
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
  4. #54
    Nov 2007
    I am havin problem in embeding my GPS application.
    when GPS button pressed nothing sows up just a balnk screen with audio controls below.
    I am using Mireo BLackEdition GPS. http://www.mireo.hr/Navigation.aspx
    I have attahced the screenshot og the rrconfig.
    help me finding the problem, GPS MODE should i select external?
  5. #55
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by monty9991 View Post
    1. Is that the correct path to the program exe?
    if so does that application actually start up
    2. If it does start then check the window name is correct, look for an app called winspector to help find it.
  6. #56
    Nov 2007
    yes the pths is correct, used same path in centrafuse and it worked.
    no, the application does not starts even in the background.
    window name is also checked sevral times with winspector.
  7. #57
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well if you have external checked and the correct path in there, then issuing a GPS command should start the exe.
    If it doesn't then one of the following apply
    1. It is not the correct path.
    2. The GPS command has possibly been hijacked in an exectbl.ini
    3.You are not issuing the GPS command but possiblt a direct load;external_gps.skin command.
    4. There is a conspiracy to stop you using this GPS app.
  8. #58
    Nov 2007
    the path is correct, i have checked it again.
    can you be more specific on the 2,3 and 4 point. you using programmer's language and i am not gettin it.
  9. #59
    Nov 2007
    i got this thing working . there was some problem in my laptop running vista not lettimg me to chage the file. so i ran it on my desktop running xp and worked.
    but now i havea little problem. i dont want to use the skin's button i want to use the butons which are with the software.
    and the skin is chopping the gps screen from bottom. i have attached the pictures to compare, how it looks and how it should look.
  10. #60
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looks like it is not letting you resize it small enough.
    in the external_gps.skin you can change the c (clip) line
    c,x,y,w,h
    make the h value higher, problem is, if you lose those bottom buttons you will not have a way of exiting that screen
  1. Replies: 16
    Last Post: 09-05-2007, 04:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 04:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 03:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 06:36 PM
