Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 88
Thread: How to Embed any GPS program into Road Runner
  1. #71
    Jul 2010
    I found the problem! Well, I found the fix. In RRConfig under the GPS settings, I changed it from External to Menu. Now when I press the Nav button in RR it brings up a menu with 3 options. One of them is Garmin Mobile. I select that and Garmin loads as an embedded app and even has an OSK built in. This rocks. It would be nice to not have that one extra click but whatever. It's a small price to pay for working GPS.
    I read so many articles on people having issues with GMPC especially related to OSK. I was just about ready to switch to MS Streets and Maps. Now I don't gotta. GPS works great and I tether my IPHONE to the PC and I can even get Garmin online service. SWEET!
    Thanks for everyone's help.
    D
  2. #72
    Aug 2010
    Hi,
    i'm modifying the Garmin frame so i can easily jump from navigation to Radio/MP3 Player and back with just one button. Kinda looks like this now...
    As you can see at the bottom, i also made a space where the Tracktitle and artist are shown, as well as the time and date. and here's the problem:
    the line does not refresh itself automaticly.
    the clock stands still untill u hit vol up or down or any other button on top.
    anyone know what to do?
    EDIT
    I helped myself by using the top of the Garmin menu and using the bottom from the "external gps" menu. throwing out the buttons and adding Title/track or RDS info as well as date and time. orange letters on black background looks beautiful:
    Last thing to do, make the top bar look nicer. maybe put some icons there....
    at least it works.
    The modified pics and menus can be downloaded here:
    http://rapidshare.com/files/41327236...n-extended.zip
    Have fun
  3. #73
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Having problems trying to Embed Garmin Mobile PC.
    I checked the path and the Window name which is:
    GPS Path:e:\GarminMobilePC\que.exe
    GPS Window Name: Garmin Mobile PC
    It does open on top but does not embed. When I drag the window somewhere it will "pop" back where it was but is not embeded. It covers some music buttons on the bottom of the BMV2 skin & is still on top of the skin.
    I used findwindowinfo & Winspector Spy to get the Window name.
    Any ideas why it does not embed?
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  4. #74
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by michaelrj9 View Post
    Please post the button code you are using to open Garmin and attach the skin file you are trying to embed it into.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  5. #75
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by drewbp View Post
    Show me the code you use to open the program.
    Not sure exactly what you need but:
    My location of Garmin is e:\GarminMobilePC\que.exe. If I double click Que.exe out of RR it opens up Garmin. I used FindWindowInfo from RR's FAQS section. It shows the window name as "Garmin Mobile PC"
    So In RR Config it is setup as:
    I also tried to embed Garmin Mobile PC through RR'S APP'S but same thing happens. For some reason It does not want to work with Garmin. I know it can be done as others have said it works but I can't get it to work.
    I am a newbie to a lot of stuff with RR but have embeded different programs and they work.
    Michael
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  6. #76
    Feb 2005
    Huntsville, AL
    Is this what you need?
    E:\GarminMobilePC\Que.exe
    & skin file
    Attached Files Attached Files
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  7. #77
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Yes that is what I was looking for but I was thinking of embedding regular apps, not GPS which is all configured in RRconfig, so it does no good for me to look at it. Look a few posts up where myrddin33 talks about choosing GPS menu rather than external and you will see others with the same problem and a fix.
  8. #78
    Low Bitrate volvoman1's Avatar
    Jan 2010
    iGuidance won't embed properly for me. RR with eLite skin. When I hit the iGuidance button, the GPS menu comes up but iGuidance doesn't load. Please see attached screenshot.
    The path is correct. If I paste it in "run", it starts the application. I am running Windows 7 Ultimate, 64 bit.
    Help!
  9. #79
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by volvoman1 View Post
    Help!
    Quote Originally Posted by Enforcer View Post
    If it opens but does not embed, it will be down to one of two things.
    1. The window name is incorrect. (use winspector to find correct window name)
    2. The program does not like resizing and won't embed.
    Second post has now been converted to an FAQ post, starting with the above.
    An FAQ post required for an FAQ thread, who'd have thought it?
  10. #80
    Jan 2010
    Thanks for the reply but the window name is set correctly in RRConfig and since it is iGuidance, it will embed..something just isn't right here.
    Any other ideas? Thanks in advance.
  1. Replies: 16
    Last Post: 09-05-2007, 04:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 04:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 03:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 06:36 PM
