Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 107
Thread: How to Embed any GPS program into Road Runner
  1. #81
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Have you tried it with the carwings skin? /Mitchjs mode
    Try running iGuidance outside of RR and then running RR and select GPS iGuidance.
  2. #82
    Low Bitrate volvoman1's Avatar
    Jan 2010
    Quote Originally Posted by Enforcer View Post
    What does this acheive? I tried it and it shows RR running on top with iguidance in the backround, not embedded.
    As for Carwings, i don't have it set it to run iguidance so i haven't tried it.
  3. #83
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by volvoman1 View Post
    Well if the window name was correct then RR would grab the already running iGuidance and imbed it.
    Now my experience is all on pre windows 7 boxes.
    I'm not sure if windows 7 has brought any of it's usual issues with embedding apps like it does with audio and some other display quirks.
    Make sure aero is off.
    Check the iGuidance window name with something like winspector just to make sure it is correct (newer version may be different from the older versions, unlikely but possible)
    Try it with iGuidance native unchecked.
    try it without menu and just as external app and have a button execute the GPS command, hell just use skintool to send the GPS command.
  4. #84
    Jan 2010
    It embedded when I had external checked...not sure why but it works!
    Thanks for your help.
  5. #85
    Dec 2004
    I've found the "GPS Window Name" for a few GPS programs for Ride Runner.
    If Map Monkey doesn't work correctly using it built in like it did for me and you want to use it as a external GPS program instead the information is:
    Map Monkey
    GPS Window Name = Map Monkey
    Roadnav
    GPS Window Name = RoadNav
    Navit
    GPS Window Name = Navit
    Delorme Street Atlas 2008
    GPS Window Name = DeLorme
  6. #86
    Jul 2011
    iGuidance launch and embed issues
    Hello. I'm new to this forum, but have spent countless hours reading this forum on setting up a carpc as my system.
    I've got mostly everything set up already. The only issue I'm having is getting the iGuidance 2011 application to launch and embed in RR.
    RR Config does not have a GPS Path option. Below is an image of the RR Config window.
    If you launch iGuidance first and RR after. Then the Navigation buttons in RR will work with iGuidance, but iGuidance runs in the background. Which defeats the purpose.
    The threads I've read contain helpful information, but I don't see people having issues with the latest iGuidance and RR apps.
    Any help would be greatly appreaciated.
    Jun 2012
    Las Vegas, NV
    So did you figure it out?
  8. #88
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Skecher193 View Post
    Bit late, but did you try looking at the IG Native Settings?
  9. #89
    Feb 2014
    The Netherlands
    Link for downloading iGo 8 seems to be out, does anyone have one? I'd like to try it out before buying it, if possible.
  10. #90
    Dec 2010
    Twilight Zone
    Just getting into CarPCs and RR myself, and seeing the main post in this thread has not been updated in almost 6 years, can someone fill us in as to what the main/current Guidance programs people are using is?
    Most links do not seem to work, and not sure if there are any newer/better programs.
    Thanks in advance!!
    As of 4-10-14
    CarPC Progress: 60%+ Starting from scratch with old laptop. Trying to figure out how to get all the programs I want/need for RideRunner!
    My Build/Install Thread
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 05:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 04:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
