Page 1 of 9 123456789 LastLast
Results 1 to 10 of 86
Thread: How to Embed any GPS program into Road Runner
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Last Updated:
    13/11/2008
    These are the embedding commands used in the GPS configuration on RRConfig (Road Runner - Front End) based on the default paths (See bottom of page for example):
    Supported GPS Programs
    PC Navigator 7.1
    Product Home Page:
    http://directions.ltd.uk/laptop-navigation
    http://www.mapfactor.cz/en/products/...usa-and-canada
    Latest software patch/update:
    http://static.mapfactor.com/files/pc...h-7_1_13-1.exe (adds window support)
    Links To Research:
    http://www.mp3car.com/vbulletin/gps/...-7-europe.html
    Video Of It In Action:
    [media]http://www.youtube.com/watch?v=aDXyNjZA3aU[/media]Embedding Details:
    GPS Path:C:\Program Files\Navigator7\PC_Navigator\PC_Navigator.exe
    GPS Window Name:Navigator
    Garmin Mobile PC
    Product Home Page:
    https://buy.garmin.com/shop/shop.do?...484&pvID=14861
    http://www.garmin.com/software/GarminMobilePC_50010.exe
    Embedding Details:
    GPS Path:c:\GarminMobilePC\que.exe
    GPS Window Name: Garmin Mobile PC
    Sygic Drive
    Product Home Page:
    http://www.sygic.com
    Download Demo Version
    Licence for software is paid for by buying maps see this link http://www.sygic.com/carpc/index.html and download it here:
    http://rs5.rapidshare.com/files/66009309/DRIVE_XP.ZIP (Version 7.0)
    Links To Research:
    http://www.mp3car.com/vbulletin/gps/...-drive-pc.html (Main discussion page)
    http://www.sygic.com/manuals/manual_en.html (owners manual)
    [media]http://youtube.com/watch?v=LjrnfVDmO78[/media]Embedding Details:
    GPS Path=C:\DRIVE_XP\drive.exe |-no-safety -r800x530 (adjust resolution accordingly)GPS Window Name= Sygic DRIVE
    iGuidance (Both 3.0 and 4.0 Versions)
    Buy it here:
    http://store.mp3car.com/iGuidance_4_..._p/sof-019.htm (US $109.00)
    http://www.inavcorp.com/upgrade/navigation/upgrade.php
    Links To Research:
    http://www.mp3car.com/vbulletin/gps/...-v4-0-a-3.html
    [media]http://www.youtube.com/watch?v=YWoxbmm2xuEmedia[/media]Embedding Details:
    GPS Path:C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    GPS Window Name: iGuidance
    Map Monkey
    Download Full Version (Freeware):
    http://cruise247.s0ulassassins.co.uk.../MapMonkey.exe
    Licence for software is paid for by buying maps, but unfortunetley this software is based on the Desitnator D3 Engine, which is now discountinued, you will need to purchase older maps for this to work (I have read some reports that certain newer maps have worked, but be warned!)
    Links To Research:
    http://www.mp3car.com/vbulletin/map-monkey (Main MM forum)
    http://www.mp3car.com/vbulletin/mm-faqs (MM Faq)
    http://www.mp3car.com/vbulletin/mm-skins (MM Skins)
    [media]http://www.youtube.com/watch?v=rbSGlYH-OPg[/media]Embedding Details:
    GPS Path=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    GPS Window Name = I believe is natively in RoadRunner so not needed
    Free Drive
    http://www.freedrive.co.uk/forums/lo...ks.php?catid=1 (You will have to register on the freedrive forums 1st before you can download)
    http://www.mp3car.com/vbulletin/free...st1149594.html (This is enforcers personal version, seen as freedrive is now abandoned, this version is the most complete, make sure you download the original version 1st)
    Links To Research:
    http://www.mp3car.com/vbulletin/freedrive (Main mp3 FD forum)
    http://www.freedrive.co.uk/forums/lo...ks.php?catid=4 (Skins)
    [media]http://www.youtube.com/watch?v=PeE_lw7ssW0[/media]Embedding Details:
    GPS Path=C:\Program Files\FreeDrive\FreeDrive.exe
    GPS Window Name=FreeDrive
    MapPoint
    NOTE: Mappoint support is available built-in RR. There's no need to embed it as long as you use a skin which supports mappoint for GPS. Otherwise, this information below can be used for launching it as a standard application (NOT recommended).
    Product Home Page:
    http://www.microsoft.com/mappoint/pr...6/default.mspx
    Embedding Details:
    GPS Path:C:\Program Files\Microsoft Mappoint\Mappoint.exe
    GPS Window Name: Mappoint
    Map Point 2009 Europe Edition
    GPs Path: C:\Program Files\Microsoft MapPoint Europe 2009\MapPoint.exe
    GPS Window Name: Map - Microsoft MapPoint Europe
    Streets & Trips
    Product Home Page:
    http://www.microsoft.com/streets/Pro...s.aspx?pid=004
    Embedding Details:
    GPS Path:C:\Program Files\Microsoft Streets and Trips\Streets.exe
    GPS Window Name: Map - Microsoft Streets & Trips
    NOTE: Some version use the window title of: (The AND spelled out) Map - Microsoft Streets and Trips
    Unofficial GPS Programs
    I Go 8
    Read/Get iGo MySize HERE, then use:
    GPS Path=C:\GPS\iGO 8\iGO-MySize.exe|-width=800 -height=412
    GPS Window Name=iGO8
    (Adjust the width/height according to your skin)
    Tom Tom 5/6
    This can only be used using a Windows CE emulator which can be quite complex and/or slow.
    Use Blue ZX3 RRConfig (As including in the latest RR releases)
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    F.a.q.
    F.A.Q. on the above FAQ.
    Q. When I click the NAV button <your Navigation program> does open but it's not embedded. It just opens as a program in front of RR.
    A.
    If it opens but does not embed, it will be down to one of two things.
    1. The window name is incorrect. (use winspector to find correct window name)
    2. The program does not like resizing and won't embed.
    Q. I've finally got it embedded and working, however now it's not receiving any satellite signal. (I think this is because RR is intercepting it from the com port)
    A
    . Either use a com port splitter or don't enter a value for GPS port in RRConfig.
    My Fiero Build Thread
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Great idea. It should be expanded to all apps (not just GPS) like for instance the "sexy attached Analyzer" that's difficult to embed without just the right window name (which i don't remember right now).
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Good reference material!
    Cheers
    Leonardo Da Vinci
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    im gald to see the intention was to add more than the original 3 that were posted can wait to see a completed list
    Nov 2006
    Wales, UK
    Quote Originally Posted by JohnWPB View Post
    List updated
    Quote Originally Posted by treetop777 View Post
    Ok, il add sub categories, just post whatever the details are in the same format, and ill add it
    Keep em coming, anyone that can fill in the blanks
    CarPuter Progress:
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Map Monkey
    Free Drive
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Thumbs up Thank for the info!!
    While waiting on my HD Radio cable I'm moving to my next add-on and this is a big help thanks.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Ok Thread is now a sticky. Please keep all posts on topic and no unnecessary posts
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    hha meddler beat me to the punch I was watching the thread to see more items added before making it a sticky. I edited the title of the thread, as it is now a sticky, and did not need the )May want to make a sticky) in the title.
    I also edited the post to include a link to iGuidance, as well as the price.
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Replies: 4
    Last Post: 04-29-2005, 05:16 PM
  4. The Ultimate GPS Test ( Lake District )
    By Jamez_Warner in forum Off Topic
    Last Post: 04-28-2004, 04:45 AM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
