Can the "USB Drive" be an un-protected partition on the protected drive? Or do I have to use a USB?
-CoryF
-CoryF
2001 Camaro SS #2070
NOPE, HAS TO BE A USB DRIVE!
unprotected drives, while unprotected, are still cached in the hibernation file
the whole EWF is a hack by microsoft...
im sure it will be better on next embedded os![]()
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Well, my interpretation of embedded is not quite the same as running xp with ewf/horm. In an embedded system you usually have the "image" written in a ROM type memory and any thing that would change would be written to ram. So its like comparing apples to oranges...
Makes sence in my head, but probably not here..hehe
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
I've used just about all flash drives in my possesion from SanDisk, M$, Kingston, to a couple of generic ones and they all worked.
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
Okay guys, I need some help. I followed the directions in the first post, and everything seems to be working well... except when I restart the machine, I get this prompt:
What am I doing wrong guys? How can I disable that message and not have to use a keyboard to get past it?The last attempt to restart the system from its previous location failed.
Attempt to restart again?
Delete restoration data and proceed to system boot menu
Continue with system restart
If you've set up HORM correctly, restarting should result in the machine resuming, not restarting, unless you interupt the restore sequence. Iin which case, you'd get the message you described above.
Check your HORM setup.
FYI, has nothing to do with RideRunner...
get HORM working, before messing with RideRunner
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Sorry, I guess I worded that incorrectly. I get that message when I power the machine back on into a resume state. I didn't think that it had anything to do with RR, but I was hoping you guys may have run into the same problems. I don't think I am interupting the restore sequence, everything seems to be going normal until I hit that prompt.
You mentioned getting HORM working first. Does this feature of RR also require the HORM.dat file on the root drive? Do I still need to unmount my second partition (or physical drive) before I do a hibernate through RR?
What is this feature actually doing with all the .ini files on the usb drive? I am just trying to get a better understanding of what is happening with my problem. Sorry for all the questions.
Oh and a note I have found out through my trials. My old SanDisk Cruzer Mini (256mb) usb drive does not like to consistently power up when booting into Windows. It will be found while the bios starts, but then shuts off before Windows boots. It will show back up if you remove and plug it back in though. My newer 4GB SanDisk Cruzer Mico seems to work fine every time. Strange.
