Guide to using RR v4-1-09 NEW HORM features for EWF Systems
Requirements:
- EWF setup and enabled
- RR v4-1-09 and Winamp must be installed on the EWF protected drive (installing on a unprotected drive will cause corruption errors)
- USB flash drive (USB external harddrives won't work)
1: Check to make sure you have the following settings in rr.ini:
hibernateaware=true
hormdrive=x (where x is the drive letter of your connected usb flash/thumb drive without the ":\"; i.e. e, f, g, etc.)
2: Connect usb drive
3: Start RR
4: Clear Winamp Playlist
5: Make sure you have all your required programs running or not running (i.e xport, gpsexec.exe, iGuidance, etc.)
6: Hibernate thru RR
You have now set your HORM point.
After you resume and add your playlist, listen to radio, whatever, it is IMPORTANT to shutdown the system. Shutting down SAVES your resume information to the USB drive to be used on your next powerup/resume.
If you've setup your EWF system correctly, even after shutting down your sytems will result in your system resuming everytime.
If you find that you are not resuming the last playback position, adjust the following rr.ini setting:
resumedelay=x (where x is in seconds)
(this allows TIME for the USB drive to reconnect to the system)
and repeat the steps above.
Simple.
Big thanks mitch for his hard work on getting this feature working correctly.
ALSO, look at DEBUG.txt, there is alot of HORM info there
