Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Guide to using RR v4-1-09 NEW HORM features for EWF Systems
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Requirements:
    - EWF setup and enabled
    - RR v4-1-09 and Winamp must be installed on the EWF protected drive (installing on a unprotected drive will cause corruption errors)
    - USB flash drive (USB external harddrives won't work)
    1: Check to make sure you have the following settings in rr.ini:
    hibernateaware=true
    hormdrive=x (where x is the drive letter of your connected usb flash/thumb drive without the ":\"; i.e. e, f, g, etc.)
    2: Connect usb drive
    3: Start RR
    4: Clear Winamp Playlist
    5: Make sure you have all your required programs running or not running (i.e xport, gpsexec.exe, iGuidance, etc.)
    6: Hibernate thru RR
    You have now set your HORM point.
    After you resume and add your playlist, listen to radio, whatever, it is IMPORTANT to shutdown the system. Shutting down SAVES your resume information to the USB drive to be used on your next powerup/resume.
    If you've setup your EWF system correctly, even after shutting down your sytems will result in your system resuming everytime.
    If you find that you are not resuming the last playback position, adjust the following rr.ini setting:
    resumedelay=x (where x is in seconds)
    (this allows TIME for the USB drive to reconnect to the system)
    and repeat the steps above.
    Simple.
    Big thanks mitch for his hard work on getting this feature working correctly.
    ALSO, look at DEBUG.txt, there is alot of HORM info there
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    MySQL Error
    Oct 2004
    TY for the Mini-Guide!
    Oh, if you use RRCONFIG to set your HORM save Drive, make sure you have it plugged in before u start RRCONFIG
    it will see that a USB Removable drive is present, and offer that choice for HORMDRIVE
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2006
    Sun Diego
    Quote Originally Posted by mitchjs View Post
    Good to know.
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Is EWF-HORM only available on XPe? Or can it also be enabled on XP Home?
    Thanks....
    Mark
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
    Aug 2006
    Sun Diego
    Quote Originally Posted by mstaedt View Post
    Thanks....
    Mark
    Theres a tutorial under Optimization forum that can take some of the features of XPe and apply them to XP Home. Namely, EWF.
    May 2006
    Calgary, Alberta
    Shouldn't a guide for setting something up explain what it is?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Aug 2006
    Sun Diego
    Already of plenty of info in the archives that explains the nitty gritty of HORM & EWF.
    Besides, to utilize the info posted above, the user should already know about the topic at hand before attempting to use the new HORM features of RR.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And if one has to ask what is HORM OR EWF then they need to research lots before even asking any Q's.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jul 2006
    So the only thing the usb drive is used for is to store the resume data, correct?
    MySQL Error
    Oct 2004
    yes... im sure it can be used for other stuff too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 3
    Last Post: 12-11-2007, 06:07 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Is there a guide to getting voice recognition in RR?
    By vettejock99 in forum Road Runner
    Last Post: 12-26-2006, 05:47 PM
  4. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
