Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 68
Thread: How to use Girder with Road Runner
  1. #31
    Aug 2004
    Nevermind found an old igor plugin works fine.Is there any support for ig ?
  2. #32
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    did you guys know the firefly has profiles for a lot of popular programs like powerdvd,windvd and even winamp. Its in the All Users\Application Settings\Snapstream\Profiles folder.
  3. #33
    May 2005
    Germany
    Hello,
    I downloaded the file "Tay firefly". How can I use the file with my remote and RR? I installed Girder and have a serial Ir.
  4. #34
    May 2005
    Germany
    Hi,
    now I can use the universal commands in RR. But how can I use different commands for each skin.
    For example:
    Button 1 (from my remote) should be next song in audio-player but in menu.skin should this button load gps.
    Ti-ejtsch
  5. #35
    May 2005
    Germany
    Hello,
    Could nobody help me? ^^
    Is there noone who control RR via remote?
    Ti-ejtsch
  6. #36
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    powermate girder file
    i've been working on a powermate girder file
    you must have the powermate and alarmtimer plugin enabled.
    the following actions are supported
    right
    left
    down-right
    down-left
    single click
    double click
    hold 1 second
    hold 2 seconds
    it would be fairly easy to add more hold counts but i felt that it would be too distracting to try to count the audio notifications.
    in some screens, 8 commands were not enough so i made 2 command sets using the above commands. to switch between the 2 i used the hold for 1 second command, so instead of 8 commands, i now have 14 per screen.
    to define the rr function for the powermate command, just add them to your Exectbl.ini file.
    in my ExecTBL.ini i've finished the powermate commands for the menu and the audioplayer screens so far.
    /, Powermate Commands
    "LEFT1","CTRLLEFT",menu.skin
    "RIGHT1","CTRLRIGHT",menu.skin
    "LEFTDOWN1","RRPREV",menu.skin
    "RIGHTDOWN1","RRNEXT",menu.skin
    "SINGLECLICK1","CTRLEXEC",menu.skin
    "DOUBLECLICK1","LIST",menu.skin
    "HOLD1","AUDIO",menu.skin
    "LONGHOLD1","ACTIVATE;iGuidance||GPS",menu.ski n
    "LEFT2","CTRLLEFT",menu.skin
    "RIGHT2","CTRLRIGHT",menu.skin
    "LEFTDOWN2","RRPREV",menu.skin
    "RIGHTDOWN2","RRNEXT",menu.skin
    "SINGLECLICK2","CTRLEXEC",menu.skin
    "DOUBLECLICK2","LIST",menu.skin
    "HOLD2","AUDIO",menu.skin
    "LONGHOLD2","ACTIVATE;iGuidance||GPS",menu.ski n
    "LEFT1","UP",audio_player.skin
    "RIGHT1","DOWN",audio_player.skin
    "RIGHTDOWN1","RRNEXT",audio_player.skin
    "LEFTDOWN1","RRPREV",audio_player.skin
    "SINGLECLICK1","SETNEXT",audio_player.skin
    "DOUBLECLICK1","PLAY",audio_player.skin
    "LONGHOLD1","MAIN",audio_player.skin
    "LEFT2","PGUP",audio_player.skin
    "RIGHT2","PGDOWN",audio_player.skin
    "LEFTDOWN2","RRPREV",audio_player.skin
    "RIGHTDOWN2","RRNEXT",audio_player.skin
    "SINGLECLICK2","SETNEXT",audio_player.skin
    "DOUBLECLICK2","PLAY",audio_player.skin
    "LONGHOLD2","MAIN",audio_player.skin
    Attached Files Attached Files
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  7. #37
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks Kuo,
    Your GML file is the best! Did you check out your GML I sent you? I added visual notifications and a menu system to get around other RR menus.
    Going to use your latest one now, thank you for shareing this.
    Is there a way to adjust the sensitivity of rotation of the powermate knob in list mode? I find in the car over a bump you can over scroll quite easily.
    Sound Stage
    Eclipse|MTX|Infinity
  8. #38
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    try using the powermate control panel (powermate.exe) to adjust the sensitivity. you can also adjust the antirepeat time for each event in girder.
  9. #39
    Low Bitrate 05MaXSL's Avatar
    Feb 2006
    Brooklyn, NY
    Great info...where can I download the alarmtimer plugin?
  10. #40
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    So I have the igor usb device and the MCE usb device. Using girder are there a list of send messeges for each function or do you have to setup the ExecTBL.ini file. I am a little confused.
    I have used girder before with frodplayer using send keys and send messeges.
    I download the tay firefly file but i assume you need to have that remote or some other thing because it didn't work. Also i should note that i didn't edit the exectbl.ini. Is that necessary.
    Forgive my ignorance
  1. Does frodo support SHN files?
    By ayclens in forum FrodoPlayer
    Last Post: 11-07-2004, 06:15 PM
  2. Playing different types of music and video files
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-10-2003, 11:26 AM
  3. Looking for keys/buttons for custom keypad
    By izaram in forum General Hardware Discussion
    Last Post: 04-23-2002, 11:58 PM
  4. Motherboard POST time
    By Oldschool in forum General Hardware Discussion
    Last Post: 12-19-2001, 07:45 PM
