Quote:
Originally Posted by camsgs3
:nw: anyone...
Printable View
:nw: anyone...
For all I know there are different X10 remotes available, I have an ATI one that came with my video card and it is also a X10 remote.. always had it in the car, it always worked, and I hardly ever use it since I have a touch-screen.
whaaa!! :chase:
since the last update my powermate doesn`t work any more.
in girder i already changed the file from rr.exe to RoadRunner.exe (in keyboard>target)
i use this file;
http://www.mp3car.com/vbulletin/show...8&postcount=36
what do i need to change more?
something with this? classname: ThunderRT6FormDC
as you mentioned, you need to open girder and for each command on the left, change the "Target" from 'rr.exe' to RoadRunner.exe. I did this today, it only takes a minute if you leave RR open as you can select it from the list above after you click the button "Target" -- but you have to do it for EACH command though. Make sure only the checkbox in front of "RoadRunner.exe" is checked (and the the other checkboxes are not). Other than that, all I can say is that it is in fact working with the latest versions.
Hi Guino, (or any Girder-specialist ;-))
did you ever manage to set up the ATI Remote so that the "<<" and ">>" buttons work as they should (short press = next song, long press doing a fast forward within the song)?
It must have to do with the 3 differnet states of the buttons, that girder recognizes. (Button-down, Button repeat, Button-up)
I tried so hard, but could't figure this out...
Thanks anyone else who can help me.
OK. After all I found the answer myself...
Some more googling gave me the important hint about the Alarmtimer Plugin in Girder...
Works as follows (Girder 3.2 with a X10-remote):
-activate "AlarmTimer Plugin" in Girder Plugins
-add a command ">>-Timer_DOWN", as Eventstring learn "FF-Button Down"
-on the Plugins-TAB select Alarmtimer,
-press Settings: Timeout 600ms, press "ON CANCEL" and select your command that sends "NEXT" to RR. press "ON EXIT" and select the "FFWD"-command.
-make second timer with the same timer ID (important!) and set this one timout=0, NO commands for enter, cancel, exit. (this one cancels the first timer if the button is released). Learn this command with eventstring of "FF-Button-UP"
-only thing I had to do now was to learn the "FF-Button-Repeat" Event to the "FFWD" command, but give it a Antirepeat- Wait-Time of 500ms
After that do the same things for the "<<"-Buttons.
Sounds complicated maybe, that's why I attach this part of my Girder-File. the eventstrings are for a X10-remote (like ATI remote wonder), if you use another remote, you must learn the eventstrings anew.
Maybe this helps someone.
Not sure you tried it but there's a startffwd and stopffwd along with startfrwd and stopfrwd commands you can use too.
I had not yet played with press-and-hold of remote controls other than for scrolling purposes.
