Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 68
Thread: How to use Girder with Road Runner
  1. #51
    Jan 2004
    NYC
    Quote Originally Posted by camsgs3
    guys maybe im missing something, but i DL the file on the first page, learned commands to my Harmony 880[for testing] and it would not work in RR. Does that file contaygious posted only work with a certain skin, do i have to edit anything in RR.
    When i loaded the winamp plugin,i got some commands workin in RR, and ALL commands workin when i have just winamp open, but when i then load up RR, only a couple work
    any ideas
    anyone...
  2. #52
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by contaygious View Post
    6/2/05 EDIT: I just added DVD, MIXER, and PHOCO support
    dvd and mixer are in there, but you have to assign the keys to get to them in girder.
    4/24/05 EDIT: Added Video Screen commands with showcontrol button and tweaked Video Browser Toggle to work better. Also, added minimize and quit buttons...Working on phoco stuff next...
    I don't have a touchscreen, so I had to make a gml file that would allow my Snapstream Firefly remote to control mostly everything in RR. Yet, I also wanted the layout to be simple enough so that I wouldn't ever have to look down at my remote. The buttons on the remote correspond directly to the layout on the screen so it's really easy to use.
    So far, this file works perfectly for me and if you have a Firefly it should work great for you too, but if you don't then it's really easy to replace the eventstrings with your own button presses and I have included my Excel file as well so you can figure out how you want to customize yours first before you jump into the girder file.
    Just a few random notes:
    The only screens I needed were Main, Audio/Audio Browser, Vide/Video Broswer, Phone, Apps, and skin browser. If you want to add others, it's not difficult, just see how I did mine.
    I wanted to be able to scroll around on the main menu, but there is no way for Girder to recognize which button you select and thus to enable the correct group and take you to the right screen (is there?).
    It would also be cool if when a button on the remote is pressed, the corresponding icon on the screen would go in the ON position so that, for instance, when on the Audio Browser screen and the CLEARLIST button is hit, the icon would light up so that you know you cleared it, Guino?
    Added:
    Universal gamma control
    Skin browser control
    Cleaner audio/audio browser and video/video browser transitions
    I figured out the audio/audio browser and video/video browser toggles.
    You MUST have the Alarmtimer turned on in your girder settings for this to work.
    I tweaked the play command from audio browser and video browser to run smoother. It shouldn't pause now after you select something in the browsers.
    Suggestions? Hollerback!
    All, has any one done an x10 remote version of this yet ? I've lost my origonal file and was thinking about having a go with Contaygious's may be ?
    If not dont worry
    Terran
  3. #53
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    For all I know there are different X10 remotes available, I have an ATI one that came with my video card and it is also a X10 remote.. always had it in the car, it always worked, and I hardly ever use it since I have a touch-screen.
    Ride Runner RR's Myspace
  4. #54
    Jan 2003
    Quote Originally Posted by guino View Post
    They are the same but diffrent cases etc.
    Terran
  5. #55
    Dec 2003
    Netherlands
    whaaa!!
    since the last update my powermate doesn`t work any more.
    in girder i already changed the file from rr.exe to RoadRunner.exe (in keyboard>target)
    i use this file;
    what do i need to change more?
    something with this? classname: ThunderRT6FormDC
  6. #56
    guino's Avatar
    Nov 2004
    Toronto, Canada
    as you mentioned, you need to open girder and for each command on the left, change the "Target" from 'rr.exe' to RoadRunner.exe. I did this today, it only takes a minute if you leave RR open as you can select it from the list above after you click the button "Target" -- but you have to do it for EACH command though. Make sure only the checkbox in front of "RoadRunner.exe" is checked (and the the other checkboxes are not). Other than that, all I can say is that it is in fact working with the latest versions.
  7. #57
    Dec 2003
    Netherlands
    I got it working again i was also playing with my commands, so i think i destroy they girder file a little bit before i notices that i had to chance rr.exe to roadrunner.exe.
    *Note to my self: chance one thing at the time
  8. #58
    Newbie JarJarBinks's Avatar
    Oct 2006
    Heilbronn, Germany
    Hi Guino, (or any Girder-specialist ;-))
    did you ever manage to set up the ATI Remote so that the "<<" and ">>" buttons work as they should (short press = next song, long press doing a fast forward within the song)?
    It must have to do with the 3 differnet states of the buttons, that girder recognizes. (Button-down, Button repeat, Button-up)
    I tried so hard, but could't figure this out...
    Thanks anyone else who can help me.
  9. #59
    Oct 2006
    Heilbronn, Germany
    OK. After all I found the answer myself...
    Some more googling gave me the important hint about the Alarmtimer Plugin in Girder...
    Works as follows (Girder 3.2 with a X10-remote):
    -activate "AlarmTimer Plugin" in Girder Plugins
    -add a command ">>-Timer_DOWN", as Eventstring learn "FF-Button Down"
    -on the Plugins-TAB select Alarmtimer,
    -press Settings: Timeout 600ms, press "ON CANCEL" and select your command that sends "NEXT" to RR. press "ON EXIT" and select the "FFWD"-command.
    -make second timer with the same timer ID (important!) and set this one timout=0, NO commands for enter, cancel, exit. (this one cancels the first timer if the button is released). Learn this command with eventstring of "FF-Button-UP"
    -only thing I had to do now was to learn the "FF-Button-Repeat" Event to the "FFWD" command, but give it a Antirepeat- Wait-Time of 500ms
    After that do the same things for the "<<"-Buttons.
    Sounds complicated maybe, that's why I attach this part of my Girder-File. the eventstrings are for a X10-remote (like ATI remote wonder), if you use another remote, you must learn the eventstrings anew.
    Maybe this helps someone.
    Attached Files Attached Files
  10. #60
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Not sure you tried it but there's a startffwd and stopffwd along with startfrwd and stopfrwd commands you can use too.
    I had not yet played with press-and-hold of remote controls other than for scrolling purposes.
  1. Does frodo support SHN files?
    By ayclens in forum FrodoPlayer
    Last Post: 11-07-2004, 05:15 PM
  2. Playing different types of music and video files
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-10-2003, 10:26 AM
  3. Looking for keys/buttons for custom keypad
    By izaram in forum General Hardware Discussion
    Last Post: 04-23-2002, 10:58 PM
  4. Motherboard POST time
    By Oldschool in forum General Hardware Discussion
    Last Post: 12-19-2001, 06:45 PM
