Page 1 of 7 1234567 LastLast
Results 1 to 10 of 68
Thread: How to use Girder with Road Runner
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    6/2/05 EDIT: I just added DVD, MIXER, and PHOCO support
    dvd and mixer are in there, but you have to assign the keys to get to them in girder.
    4/24/05 EDIT: Added Video Screen commands with showcontrol button and tweaked Video Browser Toggle to work better. Also, added minimize and quit buttons...Working on phoco stuff next...
    I don't have a touchscreen, so I had to make a gml file that would allow my Snapstream Firefly remote to control mostly everything in RR. Yet, I also wanted the layout to be simple enough so that I wouldn't ever have to look down at my remote. The buttons on the remote correspond directly to the layout on the screen so it's really easy to use.
    So far, this file works perfectly for me and if you have a Firefly it should work great for you too, but if you don't then it's really easy to replace the eventstrings with your own button presses and I have included my Excel file as well so you can figure out how you want to customize yours first before you jump into the girder file.
    Just a few random notes:
    The only screens I needed were Main, Audio/Audio Browser, Vide/Video Broswer, Phone, Apps, and skin browser. If you want to add others, it's not difficult, just see how I did mine.
    I wanted to be able to scroll around on the main menu, but there is no way for Girder to recognize which button you select and thus to enable the correct group and take you to the right screen (is there?).
    It would also be cool if when a button on the remote is pressed, the corresponding icon on the screen would go in the ON position so that, for instance, when on the Audio Browser screen and the CLEARLIST button is hit, the icon would light up so that you know you cleared it, Guino?
    Added:
    Universal gamma control
    Skin browser control
    Cleaner audio/audio browser and video/video browser transitions
    I figured out the audio/audio browser and video/video browser toggles.
    You MUST have the Alarmtimer turned on in your girder settings for this to work.
    I tweaked the play command from audio browser and video browser to run smoother. It shouldn't pause now after you select something in the browsers.
    Suggestions? Hollerback!
    Attached Files Attached Files
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by contaygious
    I don't have a touchscreen, so I had to make a gml file that would allow my Snapstream Firefly remote to control mostly everything in RR. Yet, I also wanted the layout to be simple enough so that I wouldn't ever have to look down at my remote. The buttons on the remote corropond directly to the layout on the screen so it's really easy to use.
    The only screens I needed were Main, Audio/Audio Browser, Vide/Video Broswer, Phone, and Apps. If you want to add others, it's not difficult, just see how I did mine.
    The video/video browser controls are set up correctly, however, I believe that the video player gets in the way and prevents RR from accepting commands via remote. Same thing when in the App screen after you open an app. Guino?
    It would also be cool if when a button on the remote is pressed, the corrosponding icon on the screen would go in the ON position so that, for instance, when on the Audio Browser screen and the CLEARLIST button is hit, the icon would light up so that you know you cleared it.
    Thanks for that... I think there are now a few Girder file floating around inc mine... is it worth having another subsection in the forum like skins etc for remote control files ?
    Guino ?
    Terran
    Feb 2005
    The Yay Area (SF)
    Yeah that would be cool.
    One more thing, I didn't need volume buttons because my sound is integrated with my steeringwheel controls. So if you need that just add volume up and down to your universal commands.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    A Sticky should be in order for this.. there are not that many files ..
    Ride Runner RR's Myspace
    Jan 2003
    Quote Originally Posted by guino
    Does the same job - glad you agree... I'll put mine up later on
    Terran
    Feb 2005
    The Yay Area (SF)
    OK I updated my girder file and posted it above. Works great with vide/video browser and apps now, thanks Guino!
    Feb 2005
    The Yay Area (SF)
    Added:
    uinversal gamma control
    skin browser control
    cleaner audio/audio browser and video/video browser transitions
    Still trying to figure out a clean way to cancel out of the browser screens. Right now you either have to select something via play/select+ or go to the main menu and then back...
    I'll look into this...
    Feb 2005
    The Yay Area (SF)
    OK figured out the audio/audio browser and video/video browser toggles.
    This will be my last file unless someone wants some specific changes...well until the phone screen works.
    PEACE
    EDIT: I tweaked the play command from audio browser and video browser to run smoother. It shouldn't pause now after you select something in the browsers. It should be good to go for real now
    Feb 2005
    The Yay Area (SF)
    Feb 2005
    thanks....this is cool, just downloaded yesterday, took a while to figure out, a little hard to understand readding the excel file, can you make an nfo file explain more into detail? Like I want to add another group for dvd, how do I do that? or another command to toggle equalizer on and off? anyway, thanks, this save me alot of time.
  1. Does frodo support SHN files?
    By ayclens in forum FrodoPlayer
    Last Post: 11-07-2004, 05:15 PM
  2. Playing different types of music and video files
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-10-2003, 10:26 AM
  3. Looking for keys/buttons for custom keypad
    By izaram in forum General Hardware Discussion
    Last Post: 04-23-2002, 10:58 PM
  4. Motherboard POST time
    By Oldschool in forum General Hardware Discussion
    Last Post: 12-19-2001, 06:45 PM
