Guino> A's & about PowerDVD and WinDVDOriginally Posted by kolemieux
In case others have the same questions:
-MPC is used by RR when you set the DVD player to INTERNAL in RRConfig. RR will then use the SAME video controls to control MPC for DVD playback as it does for VIDEOS.
-There's nothing you need to do in order to make this work. Just make sure MPC's path is specified in RRConfig and that you have the DVD player set to Internal.
There's also a direct "control" interface for PowerDVD and WinDVD (Requires a skin that has powerdvd_player.skin windvd_player.skin -- i.e. BMV2):
Change the button code on menu.skin from "DVD" to either:
"LOAD;PowerDVD_Player.skin"
or
"LOAD;WinDVD_Player.skin"
then set the player in RRConfig to EXTERNAL and set the path and window title of the DVD application you're using. Note that so far I only know the brushed skins to have the above skin files required for this interface to work.
LinkBack URL
About LinkBacks
