Page 10 of 19 FirstFirst 12345678910111213141516171819 LastLast
Results 91 to 100 of 189
Thread: IBusCommunicatoRR [Update Dec17 2011]
  1. #91
    Nov 2010
    Quote Originally Posted by dpgrand View Post
    I am having problems getting this plugin to work properly with my e46. To start - all I'm trying to do is get my steering buttons to work with RR. The two volume buttons are working, but the other 4 are not.
    I have ran ibus analyzer and it sees all buttons being pressed (and I've compared msgtemplates and they are the same). So, it seems my hardware is setup correctly, but ibuscommunicatorr isn't recognizing buttons being pressed.
    As a troubleshooter, I set all RRcommands to "VOL+" but that also didn't work.
    Anyone have any ideas?
    Hi,
    You need to edit the ini file to your system as the included .ini is mine and I don't use the steering buttons.
    I use the ID# as sections and you need to delete the semicolons for all ID# you want to use (or add for those you don't want the plugin to read). For steering wheel it's ID 130 to 141
    ex. ;[ID=133] -> [ID=133]
    You also need to enter a command in the "RRCommand=" property, otherwise it wan't do anything.
  2. #92
    Nov 2010
    Upon further tweaking - i got the phone button to work. I still cannot get the other three working however. It appears the msgtemplates change between two values. For instance, > press changes between 5004C83B01A6 and 5004683B0106. What does this mean?
    That's just how your car works, the R/T button change the function of the steering wheel press button.
    When in Radio mode, the car sends 5004683B0106 ( 50 - from Steering wheel, 04 - 4 bytes, 68 - to Radio, 3B01 - button next pressed, 06 - checksum).
    When in Telephone mode, car sends 5004C83B01A6 ( 50 - from Steering wheel, 04 - 4 bytes, C8 - to Telephone, 3B01 - button next pressed, A6 - checksum).
  3. #93
    Mar 2007
    Ha. I should have been able to figure that out - but this should be noted somewhere....
  4. #94
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    That was a very nice little piece of information! I am working on a piece of sw at the moment and was very confused about the steering wheel button behaviour. Now I know what to look out for! Thanks
  5. #95
    Feb 2008
    Ireland
    Hi JanneH0,
    Great work on this plugin! I've been using IbusRR & RoadRunner since 2008 and now I decided to upgrade to RideRunner just because of your plugin!
    I haven't tested yet in the car (a lot of changes in RR so I need to do a new install and update my skin) but hope it will work.
    Compared to IbusRR, the only 2 features I would ask for are "LTS" & "SwichScreens". At the moment I'm thinking of doing my own Extension for these features but I think having them in the core plugin would work best, esp. LTS.
    Thanks again for your work!
  6. #96
    Nov 2010
    Quote Originally Posted by dan32500 View Post
    Hi dan32500,
    Don't think plugin for this features are needed as you can do it in skin file.
    Checked the LTS and if I understand correct it just send a sequence of codes to the Ibus?
    If so just use "IBusCommunicatoRR;sendtoibus;3F 0B BF 0C 00 00 00 00 21 10 00 06||WAIT;0.2||IBusCommunicatoRR;sendtoibus;3F 0B BF 0C 00 00 00 00 00 00 00 06"||WAIT;0.2||IBusCommunicatoRR;sendtoibus;3F 0B BF 0C 00 00 00 00 21 10 00 06||WAIT;0.2||IBusComm... on your button. (codes taken from the LTS config file)
    and for switchscreens, use ExecTBL
    Example taken from IbusRR config file, sequence are main->audio->gps->main and using "PHONE_PRES" to switch
    IbusCommuncatoRR config file:
    [ID=138]
    IDName=STW_PHONE_PRES
    MsgTemplate="5004C83B8027"
    Label="S. Wheel Phone Press"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="MAIN"
    ExecTBL:
    "MAIN","AUDIO",menu.skin
    "MAIN","GPS",Audio_player.skin
    And do the same for execute different command on different screens
    Cheers
  7. #97
    Feb 2008
    Ireland
    Oh yes, very smart!
    More variables from obc (from hidden menu) never hurts if you would like to add more.
    Cheers!
  8. #98
    Nov 2010
    Oh yes, very smart!
    Cheers!
    Any specific variable you missing?
    After a few month on hold I'm just finishing another major (last) update, so now are the time...
    Janne
  9. #99
    Dec 2011
    Post completing IusCommunicatoRR
    Hi JanneH0,
    I think that...
    onBoard Battery Voltage,
    ServiceInterval (Liters/Days), - who needs this?
    remaining Fuel Distance,
    remaining Fuel Distance at consumption,
    real speed,
    showed speed in IKE,
    arriving time (only for OEM Navigation),
    Consumption correction
    I don't know if these variables available on IBus... or in IKE-Display only
    but I have another question to you:
    maybe im too stupid but I can't get RR working with IBusCommunicatoRR in CD-Changer mode - I will tell you what I really want:
    I have an e39 2002 with OEM CD-Changer, AuxHeater, OEM Navi MK4, 16:9 BoardMonitor, MFL, etc.
    I want to work a Car-PC as CD-Changer (with Sound over OEM Radio BM54)
    I want to use a JogShuttle (like THIS) in my Car to control the PC AND the OEM Radio,Navi,BC,AuxHeater,etc.
    I want that the PC is comming up like the original CD-Changer, means if I press Mode (or Key1 on JogShuttle) the the BM switches to Radio --> CarPC --> Tape --> Radio
    I want that in every situation no hidden controls aktivated (like RTS switches screen to PC but Menu Turnknob controls radio or BC in background and possibly resets my consumption level)
    That is my understanding of "full integration in OEM equipment"
    Now my Problems:
    no matter if I set the CD-Emulation true or false and the Poll-Resp in CD-Changer-Section and Poll-Request in Radio-Section in IBusCommunicatoRR.ini the screen switches, but in Background always stay Radio.... and my steering wheel controls Computer AND Radio - why? (I really dont understand the "Choose CD or Tape input"-Section)
    I really think that all my wishes can fullfilled by RR+IBusCommunicatoRR, but i think i do something wrong in settings...
    here is my INI-File for your Interest:
    Code:
    [SETTINGS]
    ; General settings ----------------------------------------------------------------
    ; COM port number, Valid range 1 to 16 (Required)
    ComPort=2
    ; SW Contention, using software mode to detect bus traffic (default False)
    ; Set to True if not using Melexis based interface (Resler)
    SWcontention=False
    ; Cd emulation, simulates physical cd changer (default False)
    CdEmulation=True
    ; Amp emulation, simulates a physical amplifier (default False)
    AMPEmulation=False
    ;Saves message to RR:s debug file (default false)
    Debug=True
    ; Enable last known state of RTSEnable (default false)
    ; If True IBusCommunicatoRR will save last know state to StartUpRTSEnable
    SaveRTSEnable=False
    ; Startup RTSEnable state, True set RTS on False off (default False)
    StartupRTSEnable=False
    ; Display settings, sends TRACKNAME to IKE display --------------------------------
    ;Enable Display, True or false (default false)
    DisplayEnable=True
    ; The initial string to be displayed in the text area (default IBusCommunicatoRR)
    DisplayStartup=Angeschnallt?
    ; PDC settings, reading PDC distance from Ibus ------------------------------------
    ; Enable PDC, true or false (default false)
    PDCEnable=False
    ; Automacically switch to PDC.skin when PDC active, true or false (default false)
    PDCskin=False
    ; Set the distance unit, choose between meter inch or feet (default meter)
    PDCUnit=meter
    ; If you want to lower volume when PDC are active
    ; Set between 1 to 30 (default 10)
    ; Set to 0 to pause RR when PDC active
    ; set to -1 to disable (no pause, no volume change)
    PDCVolume=10
    ; Time from PDC "out of range" to autoexit PDC screen
    ; Set between 0 to 30s (default 15)
    PDCOffDelay=5
    ; IBUS Messages -------------------------------------------------------------------
    ; Message definition syntax
    ; [ID=ID#]		: Id# (range from 0 to 150). You can add your own message as long there
    ;			: is a free ID#.
    ;			: Id# from 151 and up are reserved, DO NOT USE.
    ; IDName		: This is the IBUS ID Name known by the IBusCommunicatoRR.
    ; MsgTemplate 		: The message template. wildcard "XX" can be used to replace
    ;			: a specific character for variable content messages.
    ;			: If wildcars are used, set the checksum byte to XX also.
    ; Label			: A clear text to describe the message, only used for debug log.
    ; Parse			: If False (default), the message is not parsed by IBusCommunicatoRR.
    ;			: If the message MsgTemplate is empty, Parse will be forced to False.
    ;			: If True the message is parsed and generate an event.
    ; System		: If True, then the message is always processed, whatever is the state of RTSEnable.
    ; RTSEnable		: If set to "Disable", then IBusCommunicatoRR will stop to generate events
    ;			: until a message with "Enable" Enable's again (flip/flop).
    ; ReplyMsgID		: If Set to a valid ID#, will send the message <ID> on the bus.
    ;			: Message will be sent only if no XX wildcards contained.
    ; ButtonState		: If Set to true, the PRESSED state will be managed automatically.
    ;			: The ReleaseID value must be set with a valid ID# for this parameter.
    ; ReleaseID		: If set to a valid ID#, will wait the msg ID before processing.
    ;			: This can be used especially when a button PRESS/HOLD state is needed.
    ; PressOrHoldID		: If set to valid ID#, will cancel a pending event (ReleaseID) .
    ;			: Useful when using different function depending on press or hold.
    ;			: This will prevent the press to execute.
    ; RRCommand		: If Set, generate the RR command sequence when ID recognized.
    ;			: You can send multiple commands at once using the || separator.
    ; CD Messages ---------------------------------------------------------------------
    [ID=1]
    IDName=CD_POLLRESP
    MsgTemplate="1804FF0200E1"
    Label="CD Poll Resp"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=2]
    IDName=CD_RADSTARTPLAY_100
    MsgTemplate="180A68390209003F00010076"
    Label="CD Start Playing CD 01 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=3]
    IDName=CD_RADSTARTPLAY_200
    MsgTemplate="180A68390209003F00020075"
    Label="CD Start Playing CD 02 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=4]
    IDName=CD_RADSTARTPLAY_300
    MsgTemplate="180A68390209003F00030074"
    Label="CD Start Playing CD 03 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=5]
    IDName=CD_RADSTARTPLAY_400
    MsgTemplate="180A68390209003F00040073"
    Label="CD Start Playing CD 04 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=6]
    IDName=CD_RADSTARTPLAY_500
    MsgTemplate="180A68390209003F00050072"
    Label="CD Start Playing CD 05 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=7]
    IDName=CD_RADSTARTPLAY_600
    MsgTemplate="180A68390209003F00060071"
    Label="CD Start Playing CD 06 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=8]
    IDName=CD_NOTPLAY_100
    MsgTemplate= "180A68390002003F0001007F"
    Label="CD Not Playing CD 01 00"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; RADIO Messages ------------------------------------------------------------------
    [ID=10]
    IDName=RAD_CDPOLL
    MsgTemplate="6803180172"
    Label="Radio Polls CD"
    Parse=True
    System=True
    RTSEnable=Enable
    ReplyMsgID=1
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=11]
    IDName=RAD_CDPLAY
    MsgTemplate="6804F04A9046"
    Label="Radio asks CD Play"
    Parse=True
    System=True
    RTSEnable=Enable
    ReplyMsgID=2
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="RESUME"
    [ID=12]
    IDName=RAD_CDSTOP
    MsgTemplate="6804F04A4A9C"
    Label="Radio asks CD Stop"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=8
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="PAUSE"
    [ID=13]
    IDName=RAD_CDSTAT
    MsgTemplate="6805183800004D"
    Label="Radio Asks CD Status"
    Parse=True
    System=True
    RTSEnable=enable
    ReplyMsgID=2
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=14]
    IDName=RAD_CDSCAN
    MsgTemplate="68051838040148"
    Label="Radio Asks CD Scan Forward"
    Parse=True
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=15]
    IDName=RAD_CDSCANB
    MsgTemplate="68051838040049"
    Label="Radio Asks CD Scan Backward"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=16]
    IDName=RAD_SETMENU
    MsgTemplate="68043B460110"
    Label="Radio Sets Menu"
    Parse=
    System=
    RTSEnable=Disable
    ReplyMsgID=1
    ButtonState=
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=17]
    IDName=RAD_MENUTIMED
    MsgTemplate="68043B460213"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=1
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    [ID=18]
    IDName=AMP_EMULATE
    MsgTemplate="C0036801AA"
    Label="AMP Emulation"
    Parse=False
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; Choose CD or Tape input----------------------------------------------------------
    [ID=19]
    IDName=TEXT_MSGCD
    MsgTemplate="680C3B0720202020200843442057"
    Label="Text Message CD"
    Parse=True
    System=True
    RTSEnable=Enable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=20]
    IDName=TEXT_MSGTAPE
    MsgTemplate="68123B2362105441504520XX20202020202020XX"
    Label="Text Message TAPE"
    Parse=True
    System=True
    RTSEnable=Enable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; Board Monitor Buttons Messages --------------------------------------------------
    ; --- Menu ------------------------------------------------------------------------
    [ID=25]
    IDName=BUT_MENU_PRES
    MsgTemplate="F004FF483477"
    Label="MENU Press"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=26]
    IDName=BUT_MENU_HOLD
    MsgTemplate="F004FF487437"
    Label="MENU Hold"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=27]
    IDName=BUT_MENU_REL
    MsgTemplate="F004FF48B4F7"
    Label="MENU Release"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- Reverse Tape ----------------------------------------------------------------
    ;[ID=28]
    IDName=BUT_TAPEREV_PRESS
    MsgTemplate="F004684814C0"
    Label="Tape Reverse Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=29]
    IDName=BUT_TAPEREV_HOLD
    MsgTemplate="F00468485480"
    Label="Tape Reverse Hold"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=30]
    IDName=BUT_TAPEREV_REL
    MsgTemplate="F00468489440"
    Label="Tape Reverse Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- Eject Tape ------------------------------------------------------------------
    ;[ID=31]
    IDName=BUT_TAPEEJECT_PRESS
    MsgTemplate="F004684824F0"
    Label="Tape Eject Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=32]
    IDName=BUT_TAPEEJECT_HOLD
    MsgTemplate="F004684864B0"
    Label="Tape Eject Hold"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=33]
    IDName=BUT_TAPEEJECT_REL
    MsgTemplate="F0046848A470"
    Label="Tape Eject Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- TP --------------------------------------------------------------------------
    ;[ID=34]
    IDName=BUT_TP_PRESS
    MsgTemplate="F004684832E6"
    Label="TP Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=35]
    IDName=BUT_TP_HOLD
    MsgTemplate="F004684872A6"
    Label="TP Hold"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=36]
    IDName=BUT_TP_REL
    MsgTemplate="F0046848B266"
    Label="TP Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- RDS -------------------------------------------------------------------------
    ;[ID=37]
    IDName=BUT_RDS_PRESS
    MsgTemplate="F004684822F6"
    Label="RDS Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=38]
    IDName=BUT_RDS_HOLD
    MsgTemplate="F004684862B6"
    Label="RDS Hold"
    Parse=True
    System=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=39]
    IDName=BUT_RDS_REL
    MsgTemplate="F0046848A276"
    Label="RDS Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- FM --------------------------------------------------------------------------
    [ID=40]
    IDName=BUT_FM_PRESS
    MsgTemplate="F004684831E5"
    Label="FM Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="PAUSE"
    ;[ID=41]
    IDName=BUT_FM_HOLD
    MsgTemplate="F004684871A5"
    Label="FM Hold"
    Parse=True
    System=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=42]
    IDName=BUT_FM_REL
    MsgTemplate="F0046848B165"
    Label="FM Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- AM --------------------------------------------------------------------------
    [ID=43]
    IDName=BUT_AM_PRESS
    MsgTemplate="F004684821F5"
    Label="AM Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="PAUSE"
    ;[ID=44]
    IDName=BUT_AM_HOLD
    MsgTemplate="F004684861B5"
    Label="AM Hold"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=45]
    IDName=BUT_AM_REL
    MsgTemplate="F0046848A175"
    Label="AM Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- (Dolby) ---------------------------------------------------------------------
    ;[ID=46]
    IDName=BUT_DOLBY_PRESS
    MsgTemplate="F004684833E7"
    Label="Dolby Press"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=47]
    IDName=BUT_DOLBY_HOLD
    MsgTemplate="F004684873A7"
    Label="Dolby Hold"
    Parse=True
    System=True
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=48]
    IDName=BUT_DOLBY_REL
    MsgTemplate="F0046848B367"
    Label="Dolby Release"
    Parse=True
    System=False
    RTSEnable=Disable
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ; --- Mode ------------------------------------------------------------------------
    [ID=49]
    IDName=BUT_MODE_PRESS
    MsgTemplate="F004684823F7"
    Label="MODE Press"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand="PAUSE"
    ;[ID=50]
    IDName=BUT_MODE_HOLD
    MsgTemplate="F004684863B7"
    Label="MODE Hold"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
    ;[ID=51]
    IDName=BUT_MODE_REL
    MsgTemplate="F0046848A377"
    Label="MODE Release"
    Parse=True
    System=False
    RTSEnable=
    ReplyMsgID=
    ButtonState=False
    ReleaseID=
    PressOrHoldID=
    RRCommand=
  10. #100
    Feb 2008
    Ireland
    Looking again at the 'e46 hiden menu' options I have to say there isn't many left - I thought there were more.
    - Fuel Left (at the moment I'm dividing range by consumption to find out the level but this is about 90% accurate)
    Looking forward to the update!
    EDIT:
    Digged up some old files and found some more possible variables:
    - Doors/windows status
    - Light Dimmer status (Data="FF FF 00 00")
    - Handbrake status (on/off)
    - Gear Status (D/P/N/R)
    - Engine status (on/off)
    - Lamp status (this might be too complicated for its use)
    Data from the IHK would be cool also.
    More info: http://ibus.stuge.se/IBus_Devices & http://ibus.stuge.se/IBus_Messages
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 05:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 02:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
