oh sorry.
is there a wow64 folder also?
I'm using 32Bbit windows!!! NOT 64bit! Look 3 section : http://postimage.org/image/uxtcvpj75/
oh sorry.
No SysWOW64 folder is only in windows 64bit. In 32 bit system and system32 folders.
I use since more than 1 year this plugin. Configured are very few IBUS messages, only Steering Wheel buttons (Next Track, Prev Track and Dial Number Button - as pause)
Since the beginning on, I have the following problem
When RR starts, shows IBusCommunicatorRR the BC values, but there is no response to configured Steering Wheel buttons. Once PDC is activated, buttons start to work until i restart RR
Where could be the problem?
I'm using Windows 7 32-Bit.
check the other settings, like rts, parse and so on.
Sorry for late response
Today i could generate logs
I turned RR's debug, plus IBusCommunicatorRR's debug, ExtendedDebug and IBusLog
After starting RR I pressed some Steering Wheel buttons - no reaction
Then I turned PDC on and off
Again Steering Wheel buttons - now with desired response
thx
Dimitri
P.S.: At the very beginning I've tried with SaveRTSEnable and StartupRTSEnable option, but not helped. I think this options are not relevant for my configuration
I think you should try with System=True.
