Page 2 of 19 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 182
Thread: IBusCommunicatoRR [Update Dec17 2011]
  1. #11
    Oct 2010
    Ivry-Sur-Seine (France)
    Thank you very much!!
  2. #12
    Oct 2010
    Hi JanneH0,
    could you add a variable for the current avg speed in km\h like $IBusCommunicatoRR_AVGSPEED$
    Also without abusing your kindness could you share your source code for this plugin. I am interested to work on this plugin.
    thanx in advance
  3. #13
    Feb 2009
    Hi
    I have tried to get your plugin to work but i cant get it to send any commands from my ride runner skin, i have the plugin in the global plugin folder, i can see the plugin registered in the debug file, i have the current RPM and coolant temp variable on my skin and they work fine by reading the values from the ibus but when i configure a button on my skin to send a command to the ibus nothing happens, i have tried using the ibuscommunicator;sendtoibus; etc.... but nothing i try works.
    Any ideas as i would really like to use your plugin?
    Matt
  4. #14
    Nov 2010
    Hi,
    Sorry for not beeing here for a while.
    Hi JanneH0,
    thanx in advance
    Yes, sure. It's the average speed value from on-board computer you mean?
    It will take a couple of weeks as I working a lot currently, but I will add it.
    Hi
    Since you can read from Ibus, plugin installation are OK
    Problem is in Tx, my guess is the bus interface.
    What Ibus interface are you using? If resler RS232 or USB?
    thx
    /JanneH0
  5. #15
    Feb 2009
    its a usb ibus adapter, its not from resler but the adapter works with all other plugins and ibus software i have tried without problems e.g. ibus analyser etc... would really like to use your plugin, its the best one i have found - my entire project i am working on rests on using your brilliant plugin
    Thanks for your help in advance
    Matt
  6. #16
    Nov 2010
    It could be it, most sw do not check if there is traffic on the bus before they send.
    Currently I'm sampling the CTS pin to check if there is traffic before i send, reason is to avoid congestion.
    Let me know what interface you using, if it's it I will work on a solution.
  7. #17
    Feb 2009
    this is the USB device i am using
    http://cgi.ebay.com/BMW-IBUS-I-BUS-U...ht_2099wt_1141
  8. #18
    Oct 2010
    Quote Originally Posted by JanneH0 View Post
    Hi,
    Yes it is this value which I speak.
    thank you again
  9. #19
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    In my application I use the fact that every sent message is echoed. Collisions are handled by hardware, at least in the resler interface, so only problem is to check that message acctually got sent. If not, resend after 25ms or so.
    Edit-> Obviously there is no use trying to send if the line is busy from the beginning.
  10. #20
    Nov 2010
    I'm not an expert but as far as i understand thats fine as long as you use a melexis based interface (like resler) cause I believe the first byte will not be sent on the bus if there is traffic. However on a descrete or other chip solution that does not have any hardware collision detect, then the first byte will be sent whether there is traffic or not.
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 05:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 02:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
