Page 3 of 19 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 182
Thread: IBusCommunicatoRR [Update Dec17 2011]
  1. #21
    Feb 2009
    Hi Janne
    Got your plugin working great now with the resler interface. Just had a quick question is it possible to have the current cd multichanger track number/name as a variable?
    Matt
  2. #22
    Nov 2010
    Quote Originally Posted by mattstevenson View Post
    Hi Janne
    Matt
    Hi Matt,
    Great to hear it's working now.
    CD# and Track# is feasable, will add
  3. #23
    Feb 2009
    Quote Originally Posted by JanneH0 View Post
    Hi Matt,
    thats brilliant news! is it easy to add new variables to the plugin? would you mind sharing the source code for your plugin? i only ask because i am working on a major carpc integration project for my range rover and I don't want to keep having to disturb you every time i need to add a new variable. My plan is to replace the standard BMW screen with a carpc but i still want to control everything to to with the cars existing system from the car pc e.g. aux ventilation, TMC etc... do you know it is possible to add any variable to the plugin or is it limited?
    Thanks for your help and fast response - looking forward to the new release!
    Matt
  4. #24
    Nov 2010
    Matt
    Hi,
    Yes it's easy to add, testing it is the time consuming part.
    No plan to release the source code now.
    You can add any variable, no limit in SW.
    Obviously there is a limit, but that depends on your HW.
    /Jan
  5. #25
    Feb 2009
    ok no problem, thanks again for all your help! looking forward to the new release.
    Matt
  6. #26
    Feb 2009
    Hi Janne
    Just got a quick question - i have the plugin working with the PDC sensors and it shows the CM distances but the sliders dont seam to work, any ideas? Also since i have started to add a number of your variables to my skin it has started to blue screen my computer - i have noticed this happens more often when i change screens e.g. if i switch from one screen showing trip computer data e.g. range, fuel etc... to another screen showing engine data e.g. RPM, coolant etc.. it blue screens the computer do you have any ideas what could be causing this?
    Matt
  7. #27
    Nov 2010
    guess it's the skin code, pls post it and I will have a look
    Have no clue sorry. Never had any blue screeen myself, also should not be related to plugin.
    /Janne
  8. #28
    Feb 2009
    /Janne
    Hi Janne
    This is the code from my pdc.skin file, it took the slider code from the pdc on your skin but cant get the slider feature to work, the CM feature works fine
    RoadRunner Skin
    ROADRUNNER pdc Skin
    S,800,352,83,50,-1,-1,0,0,H,05,"",0,"IBusCommunicatoRR_PDC_Slider_RLS" ,""
    S,164,352,83,50,-1,-1,0,0,H,09,"",0,"IBusCommunicatoRR_PDC_Slider_FLS" ,""
    S,804,291,83,50,-1,-1,0,0,H,04,"",0,"IBusCommunicatoRR_PDC_Slider_RLC" ,""
    S,154,291,83,50,-1,-1,0,0,H,08,"",0,"IBusCommunicatoRR_PDC_Slider_FLC" ,""
    S,804,229,83,50,-1,-1,0,0,H,03,"",0,"IBusCommunicatoRR_PDC_Slider_RRC" ,""
    S,153,230,83,50,-1,-1,0,0,H,07,"",0,"IBusCommunicatoRR_PDC_Slider_FRC" ,""
    L,896,359,87,34,255,255,255,22,"Arial:B","=$IBusCo mmunicatoRR_PDCRLS$cm","SCROLL-CENTER",
    L,899,298,87,34,255,255,255,22,"Arial:B","=$IBusCo mmunicatoRR_PDCRLC$cm","SCROLL-CENTER",
    L,891,176,87,34,255,255,255,22,"Arial:B","=$IBusCo mmunicatoRR_PDCRRS$cm","SCROLL-CENTER",
    L,903,236,87,34,255,255,255,22,"Arial:B","=$IBusCo mmunicatoRR_PDCRRC$cm","SCROLL-CENTER",
    S,798,171,78,48,-1,-1,0,0,H,02,"",0,"IBusCommunicatoRR_PDC_Slider_RRS" ,""
    L,51,237,87,34,255,255,255,22,"Arial:B","=$IBusCom municatoRR_PDCFRC$cm","SCROLL-CENTER",
    L,63,177,87,34,255,255,255,22,"Arial:B","=$IBusCom municatoRR_PDCFRS$cm","SCROLL-CENTER",
    L,51,299,87,34,255,255,255,22,"Arial:B","=$IBusCom municatoRR_PDCFLC$cm","SCROLL-CENTER",
    L,60,359,87,34,255,255,255,22,"Arial:B","=$IBusCom municatoRR_PDCFLS$cm","SCROLL-CENTER",
    S,165,170,83,50,-1,-1,0,0,H,06,"",0,"IBusCommunicatoRR_PDC_Slider_FRS" ,""
    B,384,519,157,83,"VOL-",
    B,729,520,134,81,"VOL+",
    I,543,517,185,89,"MUTE"
    B,543,517,185,85,"MUTE",
    B,54,517,278,86,"QUIT",
    B,864,520,161,81,"LOAD;vehicle_info.skin",
    END
    Thanks for the updated version of the plugin i have tried it out and the CD/Track feature work brilliantly! not had chance to try the sendbyid feature yet but will let you know how i get on - i am uploading a youtube video of my skin in action with your plugin which shows the cd multichanger/OBC features working in the range rover - will post the link once i have uploaded it
    Matt
  9. #29
    Nov 2010
    Hi Matt,
    Great to hear the CD function works.
    Slider:
    In your skin file there is no reference to slider style (Y0x).
    This is how it look like in my skin.
    /Sliders
    Y02,"Slider_RRS\RRS*.png"
    Y03,"Slider_RRC\RRC*.png"
    Y04,"Slider_RLC\RLC*.png"
    Y05,"Slider_RLS\RLS*.png"
    Y06,"Slider_FRS\FRS*.png"
    Y07,"Slider_FRC\FRC*.png"
    Y08,"Slider_FLC\FLC*.png"
    Y09,"Slider_FLS\FLS*.png"
    /Rear sliders
    S02,591,153,78,48,-1,-1,0,0,H,02,"",0,"IBusCommunicatoRR_PDC_Slider_RRS" ,""
    S03,598,201,78,48,-1,-1,0,0,H,03,"",0,"IBusCommunicatoRR_PDC_Slider_RRC" ,""
    S04,598,254,78,48,-1,-1,0,0,H,04,"",0,"IBusCommunicatoRR_PDC_Slider_RLC" ,""
    S05,591,302,78,48,-1,-1,0,0,H,05,"",0,"IBusCommunicatoRR_PDC_Slider_RLS" ,""
    /Front sliders
    S06,132,153,83,50,-1,-1,0,0,H,06,"",0,"IBusCommunicatoRR_PDC_Slider_FRS" ,""
    S07,124,203,83,50,-1,-1,0,0,H,07,"",0,"IBusCommunicatoRR_PDC_Slider_FRC" ,""
    S08,124,253,83,50,-1,-1,0,0,H,08,"",0,"IBusCommunicatoRR_PDC_Slider_FLC" ,""
    S09,132,302,83,50,-1,-1,0,0,H,09,"",0,"IBusCommunicatoRR_PDC_Slider_FLS" ,""
    /Janne
  10. #30
    Feb 2009
    Hi Matt,
    Slider:
    /Sliders
    /Rear sliders
    /Front sliders
    /Janne
    DOH!!
    Sorry i must have missed that, stupid me cant believe i missed that simple problem
    Matt
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 05:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 02:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 03:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
