Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 75
Thread: RRGameStation- Multi-Emulator Rom player/manager
  1. #31
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have found a new Playstation 1 emulator .
    This is PSXJin
    Just change into the graphic's configuration the size of the window by 796x464
    It is well embedded into RR but i can't launch the selected rom !
    If you have an idea why ?
  2. #32
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    ill have to download and see if it accepts params the way i have it formatted
    Live mp3Car Facebook Chat
  3. #33
    Constant Bitrate toyotatyrant's Avatar
    Aug 2007
    Hampton Roads VA
    Even though I already have several emulators running on my setup, I think I'll give this a try. This will totally rock in my dual screen skin!
    ATTENTION FELLOW CAR PC ENTHUSIASTS, POWER ACOUSTIC = CAR PC KRYPTONITE!!!! AVOID AT ALL COSTS!!!!
    To my adoring fans, No my Toyota's gas pedal didn't get stuck! Instead I saw you crossing the street and decided to floor it! Unfortunately, I MISSED!!!
  4. #34
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hey guys sorry I am a little daft. Where do I put Paths etc of the emulator(s) for the skin to point to it? The skin itself?
    RRGameStation allows users to set up to five(5) different emulators to be controlled within the plugin. User must set the following information<<< where? for the emulator to work with RRGameStation
    1. Emulator Name
    2. Emulator File Path
    3. Rom File Extension (for file search/mask)
    4. Rom Folder path (where for selected emulator are stored)
    5. Emulator Window Title
    Sound Stage
    Eclipse|MTX|Infinity
  5. #35
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by -zip- View Post
    1. Emulator Name
    %MY DOCUMENTS%\Riderunner\Plugins\RRGamestation\RRGame station_settings.xml
  6. #36
    FLAC -zip-'s Avatar
    Ontario/Canada
    TY Sonic, any idea why this is not working? Tried several combos, without slash with etc. The folder shows as NONE, but If I select it, it goes to the proper directory. I even tried placing the Snes9x.exe and all the files needed to run it in the same directory as the roms and have a single place to point to.
    <Emulator1>
    <Name>SuperNES</Name>
    <Path>C:\Emulators\Snes9x\Snes9x.exe</Path>
    <Extension>*.smc</Extension>
    <RomPath>C:\Emulators\Snes9x\Roms\</RomPath>
    <WindowTitle>Snes9X</WindowTitle>
    </Emulator1>
    Path>C:\Emulators\Snes9x\Snes9x.exe</Path> This part works well, when select is pressed Snes9x.exe loads nicely in RR. I just cant see the list with the RomPath.
    Sound Stage
  7. #37
    May 2008
    Bordeaux, France
    May be try <Extension>*.*</Extension> ?
  8. #38
    Woodbridge, VA
    Blog Entries
    41
    Did you scan the library prior to looking for the roms? Press the scan button on the bottom of RRGS_List.skin. This will read through your directories and find the roms which match your mask setting. The scan should not take very long and needs to be done each time you add/remove roms from the directory
  9. #39
    FLAC -zip-'s Avatar
    Ontario/Canada
    Scanning did not work, moved roms over to C:\Rom to make it as simple as possible. Tried this on both a Win7 machine and XP.
    Sound Stage
  10. #40
    Woodbridge, VA
    Blog Entries
    41
    can you provide me your settings.xml file and your rrgs_debug.txt file and i'll take a look.
  1. Generic MP3 player emulator ( iPod, Zen etc )
    By jbors in forum Input Devices
    Last Post: 03-11-2010, 12:06 PM
  2. HUGE Seattle-area multi-brand/multi-forum meet!!
    By ChiefyMan in forum MP3Car Gatherings
    Last Post: 08-28-2006, 03:53 PM
  3. Replies: 0
    Last Post: 03-19-2006, 12:30 PM
