Results 1 to 9 of 9
Thread: RRSavePOI - Save current GPS position as a POI - Alpha released
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    This comes as a request made by Malaki86 See this thread
    Unfortunately Malaki86 then decided to ditch RR and go back to CF, so not to waste the effort I made trying to help him I will take what he wanted and expand.
    Original Requirements
    Quote Originally Posted by Malaki86 View Post
    What I need is something like this:
    • Just before I pull into a new location, I open the plugin from RR
    • The plugin would show my info, along with a button to "lock" in the coordinates
    • Once it's "locked", I could then enter any needed info, mainly the name of the location and the city I'm in (I can manually type both of these)
    • I can then hit the "save" button to write to a specified file (If possible, disable "save" until coordinates are locked and any manually requested data has been entered) - Once written, pop up a window stating it's been saved with an "Ok" button. After this, exit the plugin
    • Include a "cancel" button to exit out of the plugin
    The CF version allowed for a custom format, such as this: %long, %lat, %1 (%2), where %long=longitude, %lat=latitude, %1=Name and %2=City.
    Suggested "built in" fields:
    • %lng - Longitude
    • %lat - Latitude
    • %time - Current time (24hr format)
    • %date - Current date (yyyy-mm-dd format)
    • %1-%9 - Custom user-specified data fields
    If possible to pull data from internet connection (or other):
    • %address - Current street address
    • %city - Current city
    • %state - Current state
    The current alpha (attached) does all the above.
    At present settings have to be edited in the ini file.
    Full Release version will have
    all the settings done within RR like all my new plugins.
    Will have extra GPS based information (whatever RR can send) as preset fields.
    If there is an internet connection will try and get street info.
    New features like GATSO, SPECS, REDLIGHT, etc
    These will allow you to create updated Speedcamera files (for this I need examples of speedcamera file formats for different navigation engines)
    Running
    You will need to add a button with the code rrsp, this will bring up the RRsavePoi screen.
    Lock - locks the current GPS coords and display time and date it was done.
    Save - will bring up the OSk and allow you to enter a description.
    Clear - clears the locked GPS coords.
    If you press save without first pressing lock the coords saved will be those that are displayed on pressing save.
    Settings
    SavePOI.ini
    GPSOveride=true - Overide GPS signal validation
    SavePath= - Path to save poi file (Default is Application Data Path)
    Filename=poi.csv - Filename of poi file (Defualt is poi.csv)
    FileFormat=%date|%time|%lat|%lon|%1 Elements to have in file and order
    autoclear=true - Whether to clear the 'locked' info after successfully saving to file
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    reserved
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Another cool plugin , that certain !!!
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    This sounds nice. but it isn't obvious to me (i may be missing something) how you would navigate back to that location..? How do you bring-up the saved information again? Oh wait, maybe it's not design to do that, it only pinpoints and identifies a location..is that it??
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I think the original idea was for the created file to be imported into a navigation programs POI or maybe it was an address book or something.
    Because you can define the format you can have the file as you want and then just import it into anything that accepts CSV formatted files.
    Looking to be able to export the speedcamera into different file formats.
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    May be you can use the GpsExec format ?
    May 2008
    Bordeaux, France
    Which is?
    This a Guino's plugin Gps alarm:
    the format is:
    ; GPS Executor Plugin for Road Runner by Guino
    ; This plugin is meant to execute any desired skin
    ; command based on the current GPS position/heading.
    ; Upon launching GPSExec, it will look for RoadRunner
    ; for 10 seconds, and if not found, it will exit.
    ; If RoadRunner Closes, GPSExec will close with it.
    ; If you wish to manually close GPSExec without closing
    ; RoadRunner, you can use the following skin command:
    ; "CLOSEWINDOW;GPSExec"
    ; Lines beginning with ; are ignored.
    ; The format of each line is the following:
    ; LATTITUDE,LONGITUDE,MINHDG,MAXHDG,DIST,UNIT,SKINCO MMAND
    ; LATTITUDE=GPS Lattitude of trigger location
    ; LONGITUDE=GPS Longitude of trigger location
    ; MINHDG=Minimun trigger heading at location (Optional)
    ; MAXHDG=Maximun trigger heading at location (Optional)
    ; DIST=Minimum trigger distance from GPS location
    ; UNIT=Unit definining Minimun trigger distance, can be:
    ; MI=Miles, FT=Feet, YD=Yards, KM=Kilometers, M=Meters
    ; SKINCOMMAND=RoadRunner Command (With Quotes)
    ; While you could use this to alert you of speed traps on
    ; your commom travel routes, I would not recommend adding
    ; thousands of items you'll never use in here.
    ; Valid Examples:
    ; I-75 IN/KY border (Northbound: 300 to 60 degrees heading)
    ;39.400080,-84.562644,300,60,100,M,"SAY;Entering Indiana!"
    ; I-75 IN/KY border (Southbound: 120 to 240 degress heading)
    ;39.400080,-84.562644,120,240,100,M,"SAY;Leaving Indiana!"
    ; Perfect North Slopes
    ;39.149989,-84.886348,,,2,MI,"SAY;Have fun snowboarding!"
    ;Test autour de Bordeaux
    44.812837,-0.555668,,,600,M,"RADAR_FIXE_130"
    44.814602,-0.572405,,,550,M,"RADAR_MOBILE_030"
    44.844612,-0.598927,,,540,M,"DANGEROUS_INTERSECTION"
    44.869191,-0.567771,,,530,M,"DANGEROUS_CURVE"
    44.872417,-0.565367,,,520,M,"NARROW_BRIDGE_AHEAD"
    44.883789,-0.560132,,,510,M,"TOOL_BOOTH"
  1. Save current location?
    By techy101 in forum StreetDeck
    Last Post: 03-03-2007, 08:16 PM
  2. IG? - Save Current Location... (Hotkey or Option)?
    By kolemieux in forum Road Runner
    Last Post: 09-02-2006, 01:28 AM
  3. Replies: 4
    Last Post: 10-11-2005, 11:14 AM
  4. GPS / Map Point current position
    By skippy76 in forum RR Bug Tracker
    Last Post: 10-10-2005, 12:42 AM
  5. current position
    By CdRsKuLL in forum FreeDrive
    Last Post: 03-14-2005, 07:52 PM
