Results 1 to 6 of 6
Thread: DL Rating System
    Jun 2011
    PA
    DL Rating System
    After messing with RRMedia for a while trying to get the stars to reset when the song plays again. I decided to make my own rating system. I wonder if I am only having problems with it because I am using vista??? either way this works.
    My system:
    -will remember what you rated each song upon playing again (even if you have closed RR)
    -has two choices:
    1. Rate Song based on Artist and Song name only (I prefer this as I have many albums of the
    same artist sometimes and this way they all are rated the same)
    2. Rate Song based on Artist, Album, Track Number, and Song Name (may use more memory??)
    -will NOT create automatic playlists (You could add a "ADDTOLIST;$PLAYLISTPATH$XSTAR.M3U"
    command to the rate button, however this will allow multiple copies of the same file. Also I do not
    know of a way to remove a song from a saved playlist if you change the rating)
    -will NOT update the stars to the song file itself whether on ipod or whatever. it will only update
    the stars within RideRunner
    The first file below is to rate by artist and song name only. The second file is to rate by artist, album, track number, and song name.
    ////////////////ADD THE FOLLOWING TO THE EXECTBL.INI/////////////////
    /------------------DL Rating System Short Version-------------------------
    "ONSONGSTART","0STAR||WAIT;1||SETVARBYCODE;TAGARTI ST;TAGARTIST||SETVARBYCODE;TRACKNAME;TRACKNAME||BY VAR;$TAGARTIST$ - $TRACKNAME$;0STAR<<1STAR<<2STAR<<3STAR<<4STAR<<5ST AR"
    "0STAR","SETIND;!5STAR;OFF||SETIND;!4STAR;OFF||SET IND;!3STAR;OFF||SETIND;!2STAR;OFF||SETIND;!1STAR;O FF"
    "1STAR","SETIND;!1STAR;ON||SETIND;!2STAR;OFF||SETI ND;!3STAR;OFF||SETIND;!4STAR;OFF||SETIND;!5STAR;OF F"
    "2STAR","SETIND;!1STAR;ON||SETIND;!2STAR;ON||SETIN D;!3STAR;OFF||SETIND;!4STAR;OFF||SETIND;!5STAR;OFF "
    "3STAR","SETIND;!1STAR;ON||SETIND;!2STAR;ON||SETIN D;!3STAR;ON||SETIND;!4STAR;OFF||SETIND;!5STAR;OFF"
    "4STAR","SETIND;!1STAR;ON||SETIND;!2STAR;ON||SETIN D;!3STAR;ON||SETIND;!4STAR;ON||SETIND;!5STAR;OFF"
    "5STAR","SETIND;!1STAR;ON||SETIND;!2STAR;ON||SETIN D;!3STAR;ON||SETIND;!4STAR;ON||SETIND;!5STAR;ON"
    "RATE5","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TRACKNAME;TRACKNAME||SETVAR;$TAGARTIST$ - $TRACKNAME$;5||5STAR||SAVETOINI;$TAGARTIST$ - $TRACKNAME$;5"
    "RATE4","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TRACKNAME;TRACKNAME||SETVAR;$TAGARTIST$ - $TRACKNAME$;4||4STAR||SAVETOINI;$TAGARTIST$ - $TRACKNAME$;4"
    "RATE3","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TRACKNAME;TRACKNAME||SETVAR;$TAGARTIST$ - $TRACKNAME$;3||3STAR||SAVETOINI;$TAGARTIST$ - $TRACKNAME$;3"
    "RATE2","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TRACKNAME;TRACKNAME||SETVAR;$TAGARTIST$ - $TRACKNAME$;2||2STAR||SAVETOINI;$TAGARTIST$ - $TRACKNAME$;2"
    "RATE1","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TRACKNAME;TRACKNAME||SETVAR;$TAGARTIST$ - $TRACKNAME$;1||1STAR||SAVETOINI;$TAGARTIST$ - $TRACKNAME$;1"
    "RATE0","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TRACKNAME;TRACKNAME||SETVAR;$TAGARTIST$ - $TRACKNAME$;||0STAR||SAVETOINI;$TAGARTIST$ - $TRACKNAME$;"
    /////////////////BUTTON COMMANDS////////////////////
    "RATE5" -RATES THE CURRENTLY PLAYING SONG TO 5 AND SETS !STARX INDICATORS 1-5 ON
    "RATE4" -RATES THE CURRENTLY PLAYING SONG TO 4, SETS !STARX INDICATORS 1-4 ON AND INDICATOR 5 OFF
    "RATE3" -RATES THE CURRENTLY PLAYING SONG TO 3, SETS !STARX INDICATORS 1-3 ON AND INDICATORS 4-5 OFF
    "RATE2" -RATES THE CURRENTLY PLAYING SONG TO 2, SETS !STARX INDICATORS 1-2 ON AND INDICATORS 3-5 OFF
    "RATE1" -RATES THE CURRENTLY PLAYING SONG TO 1, SETS !STARX INDICATOR 1 ON AND INDICATORS 2-5 OFF
    "RATE0" -RATES THE CURRENTLY PLAYING SONG TO UNRATED AND SETS !STARX INDICATORS 1-5 OFF
    ////////////////INDICATOR CODES////////////////////
    "!5STAR" -INDICATES IF THE SONG IS RATED 5
    "!4STAR" -INDICATES IF THE SONG IS RATED 4 OR ABOVE
    "!3STAR" -INDICATES IF THE SONG IS RATED 3 OR ABOVE
    "!2STAR" -INDICATES IF THE SONG IS RATED 2 OR ABOVE
    "!1STAR" -INDICATES IF THE SONG IS RATED 1 OR ABOVE
    /------------------DL Rating System Long Version-------------------------
    "ONSONGSTART","0STAR||WAIT;1||SETVARBYCODE;TAGARTI ST;TAGARTIST||SETVARBYCODE;TAGALBUM;TAGALBUM||SETV ARBYCODE;TAGTRACKNUMBER;TAGTRACKNUMBER||SETVARBYCO DE;TRACKNAME;TRACKNAME||BYVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;0STAR<<1STAR<<2STAR<<3STAR<<4STAR<<5ST AR"
    "RATE5","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TAGALBUM;TAGALBUM||SETVARBYCODE;TAGTRACKNUMB ER;TAGTRACKNUMBER||SETVARBYCODE;TRACKNAME;TRACKNAM E||SETVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;5||5STAR||SAVETOINI;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;5"
    "RATE4","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TAGALBUM;TAGALBUM||SETVARBYCODE;TAGTRACKNUMB ER;TAGTRACKNUMBER||SETVARBYCODE;TRACKNAME;TRACKNAM E||SETVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;4||4STAR||5STAR||SAVETOINI;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;4"
    "RATE3","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TAGALBUM;TAGALBUM||SETVARBYCODE;TAGTRACKNUMB ER;TAGTRACKNUMBER||SETVARBYCODE;TRACKNAME;TRACKNAM E||SETVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;3||3STAR||5STAR||SAVETOINI;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;3"
    "RATE2","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TAGALBUM;TAGALBUM||SETVARBYCODE;TAGTRACKNUMB ER;TAGTRACKNUMBER||SETVARBYCODE;TRACKNAME;TRACKNAM E||SETVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;2||2STAR||5STAR||SAVETOINI;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;2"
    "RATE1","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TAGALBUM;TAGALBUM||SETVARBYCODE;TAGTRACKNUMB ER;TAGTRACKNUMBER||SETVARBYCODE;TRACKNAME;TRACKNAM E||SETVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;1||1STAR||5STAR||SAVETOINI;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;1"
    "RATE0","SETVARBYCODE;TAGARTIST;TAGARTIST||SETVARB YCODE;TAGALBUM;TAGALBUM||SETVARBYCODE;TAGTRACKNUMB ER;TAGTRACKNUMBER||SETVARBYCODE;TRACKNAME;TRACKNAM E||SETVAR;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;||0STAR||5STAR||SAVETOINI;$TAGARTIST$ - $TAGALBUM$ - $TAGTRACKNUMBER$ - $TRACKNAME$;"
    Feel free to use my codes and critique or make suggestions!
    Jun 2011
    PA
    Does anyone know how to save to ini or skin under a specific section of the file?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    You can save either to the rr.ini or skin.ini with RideRunner code:
    (Save to Skin.ini)
    SaveToSkin;VariableName;YourInfo
    (Save to rr.ini)
    SaveToIni;VariableName;YourInfo
    There is no way, with RideRunner code, to save to a skin file itself, in a certain area. If you use variables, saving them in either the skin or rr ini's, you probably will not need to change the skin file. As the variables can be dynamic.
    You can also use include files. This is a small .txt file, that you can put labels and such in, and call in the skin like this:
    RoadRunner Skin
    ROADRUNNER menu Skin
    INC,TopIndicators.txt
    In the "TopIndicators.txt" file, is standard RR skin code, labels, indicators ect.
    This is how the indicators are done in the DFX skin, so if something changes, or to add something, it is just a matter of editing that one single file, instead of every skin.
    My Fiero Build Thread
    Jun 2011
    PA
    Thanks John, though I think you misunderstood my question. Let me try again.
    With the commands SAVETOINI (saves to rr.ini) or SAVETOSKIN (saves to skin.ini) is there a way to save the variable under a specific section of the .ini file. For example in the RR.ini all the weather settings are under [Weather]. I am considering what is in the [brackets] to be a section of the file.
    Thanks in advance.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Unfortunately with the SAVETOSKIN or SAVETOINI, they will just be placed at the bottom of the .ini if they do not already exist. Even thought it "Looks like an .ini" file, RR does not treat it as such. It just does string replacements and writes lines, essentially the same way a text file is done.
    When RR loads, it just turns all lines in the RR & Skin.ini's into variables, and ignores the [SECTIONS] entirely.
    Unfortunately, there is no "built in" read and write to .ini files in VB6. It needs to be read line by line looking for [ then ] and get what is in between (Mid$) to determine the sections.
    There are quite a few pre-programmed functions by other scriptwriters that can help. Google turned this one up as the first search result.
    If you do not want to go that route, , you can use that example above that uses RRExtended. It can read and write to certain sections using a similar function..
    Lastly, if you do not want to use RRExtended, OR API calls' you can do it 100% in script, using the code on this page.
    Jun 2011
    PA
    Great, thank you again John. Got it working with RRExtended... sort of.
    I was going to have it use a separate .ini file for the ratings however when I try and use inikeytovar command it always sets the variable to empty and does not load what is saved in the ini. Maybe it doesn't like it because my variable to load from the ini contains other variables in the name.
  1. Rating screen for RR?
    By ReflexNPG in forum Road Runner
    Last Post: 08-20-2006, 06:52 AM
  2. What is the Rating of a Fuse??
    By Boostz21 in forum General Hardware Discussion
    Last Post: 08-10-2004, 12:37 PM
  3. lcd brightness rating
    By apoc519 in forum LCD/Display
    Last Post: 04-28-2003, 02:49 PM
  4. Power rating of T6
    By SkinnyBoy in forum Power Supplies
    Last Post: 11-21-2001, 02:01 PM
  5. VA rating for P100?
    By degraz in forum General Hardware Discussion
    Last Post: 11-28-2000, 08:40 PM
