Results 1 to 8 of 8
Thread: RRandomBackground
    Oct 2010
    Ivry-Sur-Seine (France)
    RRandomBackground
    This plugin displays a background randomly either at the start of RR either a given interval or the both.
    If an interval is informed you can either apply the background to all screens (recommended) or for the current screen.
    This plugin uses the variable RRBackgroundsPath to select which background it will show. It counts the number of files in the folder and choosing one randomly.
    The setting of the plugin can be done via a skin or via a DialogBox (ie image).
    Setup in attached file
    Attached Files Attached Files
    Jun 2002
    Virginia
    Nice, fun plugin, shaken. It's working well for me. Thanks.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I say, it's a good idea !
    In french:
    Alors la , je dis bravo, trés bonne idée !!!
    May 2008
    Bordeaux, France
    Where the installer copy the skin's files please . (I am not use the profile install)
    Oct 2010
    I have not made a skin sample for the settings because there is the DialogBox and so everyone can make their own skin.
    But if you want a skin sample I can make one.
    May 2008
    Bordeaux, France
    If i try this command:
    Code:
    NUMOSKTOCMD;RRandomBackgroundupdateinterval;RRandomBackground_updteinterval
    The variable RRandomBackgroundupdateinterval don't change !!!
    Oct 2010
    Use this line (NUMOSKTOCMD;RRandomBackgroundupdateinterval;RRand omBackground_updateinterval)
    there is an error in plugin documentation for the command "RRandomBackground_UpdateInterval", I've write "NUMOSKTOCMD;RRandomBackgroundupdateinterval;RRand omBackground_updteinterval" instead of "NUMOSKTOCMD;RRandomBackgroundupdateinterval;RRand omBackground_updateinterval"
    I corrected the download link in the first post
    Thanx Pierrotm for this
    May 2008
    Bordeaux, France
    Thanks to you !
