Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: RRAussiePetrol
  1. #11
    Aug 2009
    Melbourne, Australia
    I am not going to publish the site I am using because that will be the quickest way to have page changed and the plugin will need to be changed or altered to stop us using this way.
  2. #12
    Jun 2010
    Syd, Australia
    Quote Originally Posted by Enforcer View Post
    Well each one different.
    FreeDrive is easy becasue I have the source and have added a command so it can receive GPS coords. But it's based on an old Destinator 3 engine so not many people will still use it.
    iGuidance needs a hacked version of iG and the Gasnav autoit script done originally by Sonicxtacy02.
    Sygic is a case of sending a load of keystokes to it. and which ones to send depends on which version of sygic, and what screen layout you have.
    iG08 is a KML file (basically a google earth XML file) saved in the correct location (This was orginally done for a guy in Germany and his FE and I think needs iG08 to be restarted)
    If you have a particular navigation engine in mind I can give you more details for that one.
    Are you getting the Aussie info via IE or a chrome plugin?
    Does this mean you use one of the above gps engines, feed it a lat/long (via KML file) from gps dongle, then gps engine gives you a postecode?
    If so, are we able to obtain other data from igo, such as current suburb etc?
    sorry for the hijack Michael. I think this is an interesting project. Cant wait to have fuel prices for Au!
  3. #13
    Aug 2009
    No you feed it lat/lon via KML and you get a POI you can bring up in the GPS software.
  4. #14
    Jun 2010
    Syd, Australia
    I still don't get how you get post code from the lat/long as a poi in a gps engine. And once obtained, how does that post code return to your plugin? Just trying to learn from the masters
  5. #15
    Aug 2009
    I understand what you mean.
    We use the internet to convert the lat/log to postcode and vise versa.
    once we have a pertol station lat/lon we then feed it into the GPS software for guidance.
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It's also possible to use the GPS2City within RR (I think it's now a plugin), you would just need to compile a zips.dat file for your country.
    http://www.mp3car.com/road-runner/14...-and-such.html
    post 10 in that thread has a link to postcode files for a number of countries.
    I used the internet because it was assumed the internet was available for the rest of the plugin to work.
  7. #17
    Mar 2011
    Sydney, Australia, Australia
    Hi Michael,
    Great work, I am very interrested with your plugin, I have been in touch with Enforcer on his forum for the Australian prices, but I'm guessing the website I provided didn't have the right data or it was tricky to achieve.
    I am not sure if you still need testers, but I would love to give it a go, I am using DFX5 so your skin file would do nicely
    Cheers,
    bebetaz
