ok, thanks :)
Printable View
ok, thanks :)
Hi El Camino,
I'm working on a skin for Reborn I took it over from Eugeneij because he had some trouble with it.
I have some trouble with the plugin I cant get it connect to my phone anymore. There was an update of the CC application and i was testing the Password function either one of them seem to have broken my connection. I suspect the update because i cant connect with Bluetooth either.
I have unregisterd the plugin and reregisterd it.
I can connect with the CC application without problem with WiFi or BlueTooth without problems. But not with the plugin the phone app keeps waiting for a connection. I tried reïnstalling the older version but it wont let me make a connection because of outdated software.
I am trying to get your plugin working with the default carwings skin; I have CallCenter installed and working, I also copied it into the RRDroid directory like you mentioned above. When I click on the RRDroid menu button, nothing happens. I checked the debug log, and this is what I get:
I also noticed that there is a bluetooth icon at the top right of RideRunner, but I have never seen it light up. Is there a way to enable it, or something I have to configure?Code:11:21:05.406: Enter Exec: False, menu.skin, "ONBTNPRESS||RRMenuItem;5", False
11:21:05.406: Que Exec: True, menu.skin, "ONBTNPRESS||RRMenuItem;5", False
11:21:05.406: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
11:21:05.418: Executing: PlaySound;C:\Users\Dragon\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
11:21:05.418: Que Exec: True, menu.skin, "RRMenuItem;5", False
11:21:05.418: Executing: RRMenuItem;5
11:21:05.418: Que Exec: True, menu.skin, "RRDroid", False
11:21:05.418: Executing: RRDroid
11:21:05.418: Command not executed: RRDroid
11:21:05.418: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
11:21:05.426: Executing: ONCOMMANDINVALID
11:21:05.426: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
Thank you for the reply. Yes the pi is registered, I am using BT I tried it in the test skin and it brought up the phone skin but it was blank and none of the buttons did anything. I have been searching on here and on google for any info regarding the bluetooth icon not lighting up in RR with no luck. I just have a feeling part of my problem lies there. I am just getting started with RR so if this is a dumb question im very sorry.
Tonight I uninstalled everything and started fresh with a new install of riderunner. I then went step by step through the readme. Still had the same results launch RR with test skin I can get to the phone skin/page but there is no BT connection and nothing in the contacts pane. Here are the details of my install. Windows 7 32bit, .NET 4.5, intel BT Stack. Here is the complete debug from this attempt.
Thank You!:ranger:Code:01/19:
08:04:39.297: Start -- Version: 1/1/2013
08:04:39.297: OS Type: Windows 7
08:04:39.297: FileManager: FileMode = Profile
08:04:39.297: FileManager: mypath = C:\Program Files\RideRunner\
08:04:39.297: FileManager: ProfilePath = C:\Users\Dragon\Documents\RideRunner\
08:04:39.381: Start Sequence: Starting Player...
08:04:39.381: PLAYER: Initialization creating object
08:04:39.389: PLAYER: Started
08:04:39.389: PLAYER: Winamp Version:
08:04:39.389: PLAYER: Initialization complete
08:04:39.389: Start Sequence: Starting Radio Device...
08:04:39.389: Start Sequence: Starting Serial Devices...
08:04:39.389: Start Sequence: Starting Mixer...
08:04:39.559: VMC---> Set object successful
08:04:39.598: Start Sequence: Starting Speech...
08:04:40.559: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
08:04:40.559: Plugin Manager: loading Global Plugins...
08:04:40.568: Plugin Manager: Plugin Found: Mappoint
08:04:40.568: Plugin Manager: Plugin loaded (Global): Mappoint
08:04:41.037: Plugin Manager: Plugin Found: RRDroid(.NET)
08:04:41.037: Plugin Manager: Plugin loaded (Global): RRDroid
08:04:41.059: Plugin Manager: Plugin Found: SkinTool
08:04:41.059: Plugin Manager: Plugin loaded (Global): SkinTool
08:04:41.059: Plugin Manager: Plugin Found: Weather
08:04:41.059: Plugin Manager: Plugin loaded (Global): Weather
08:04:41.088: Plugin Manager: loading Global Plugins Completed.
08:04:41.088: LoadSkin: C:\Users\Dragon\Documents\RideRunner\Skins\RRDroid Test Skin\
08:04:41.098: Plugin Manager: loading SkinDir Plugins...
08:04:41.098: Plugin Manager: loading SkinDir Plugins Completed.
08:04:41.518: Global Hotkey: Successfully registered keycode:2112
08:04:41.559: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
08:04:41.578: Enter Exec: False, menu.skin, , False
08:04:41.578: Que Exec: True, menu.skin, "ONSTART", False
08:04:41.607: Que Exec: True, menu.skin, "ONLINE", False
08:04:41.607: Que Exec: True, menu.skin, "ONSKINSTART", False
08:04:41.607: Que Exec: True, menu.skin, "ONPLAYERREADY", False
08:04:41.607: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
08:04:41.617: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
08:04:45.607: Enter Exec: False, menu.skin, "ONBTNPRESS||RRDROID", False
08:04:45.607: Que Exec: True, menu.skin, "ONBTNPRESS||RRDROID", False
08:04:45.607: Que Exec: True, menu.skin, "RRDROID", False
08:04:45.607: EXECTBL Translation: RRDROID -> ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
08:04:45.617: Executing: ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
08:04:45.617: Que Exec: True, menu.skin, "RRDroidCL", False
08:04:45.617: EXECTBL Translation: RRDroidCL -> Load;rrdroid_CL.skin
08:04:45.617: Executing: Load;rrdroid_CL.skin
08:04:46.148: Que Exec: True, rrdroid_cl.skin, "ONSCREENCHANGE", False
08:04:46.148: Leave Exec: False, rrdroid_cl.skin, ONSCREENCHANGE, False
I just noticed on my phone when I start RR my phone goes from connected to bluetooth client to waiting for for bluetooth client. Here is another log it shows more than the last one.
Code:01/19:
09:02:31.566: Start -- Version: 1/1/2013
09:02:31.566: OS Type: Windows 7
09:02:31.566: FileManager: FileMode = Profile
09:02:31.566: FileManager: mypath = C:\Program Files\RideRunner\
09:02:31.566: FileManager: ProfilePath = C:\Users\Dragon\Documents\RideRunner\
09:02:31.646: Start Sequence: Starting Player...
09:02:31.646: PLAYER: Initialization creating object
09:02:32.057: PLAYER: Started
09:02:32.176: PLAYER: Winamp Version: 5.63
09:02:32.227: PLAYER: Initialization complete
09:02:32.227: Start Sequence: Starting Radio Device...
09:02:32.227: Start Sequence: Starting Serial Devices...
09:02:32.227: Start Sequence: Starting Mixer...
09:02:32.387: VMC---> Set object successful
09:02:32.406: Start Sequence: Starting Speech...
09:02:33.580: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
09:02:33.580: Plugin Manager: loading Global Plugins...
09:02:33.590: Plugin Manager: Plugin Found: Mappoint
09:02:33.590: Plugin Manager: Plugin loaded (Global): Mappoint
09:02:34.154: Plugin Manager: Plugin Found: RRDroid(.NET)
09:02:34.154: Plugin Manager: Plugin loaded (Global): RRDroid
09:02:34.174: Plugin Manager: Plugin Found: SkinTool
09:02:34.174: Plugin Manager: Plugin loaded (Global): SkinTool
09:02:34.184: Plugin Manager: Plugin Found: Weather
09:02:34.184: Plugin Manager: Plugin loaded (Global): Weather
09:02:34.203: Plugin Manager: loading Global Plugins Completed.
09:02:34.203: LoadSkin: C:\Users\Dragon\Documents\RideRunner\Skins\RRDroid Test Skin\
09:02:34.225: Plugin Manager: loading SkinDir Plugins...
09:02:34.225: Plugin Manager: loading SkinDir Plugins Completed.
09:02:34.734: Global Hotkey: Successfully registered keycode:2112
09:02:34.805: PLAYER: Restored rrpl.m3u8
09:02:34.805: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
09:02:34.805: INFO: LoadResume() - Reading resume data from C:\Users\Dragon\Documents\RideRunner\Cache\resume.ini
09:02:34.824: Enter Exec: False, menu.skin, , False
09:02:34.824: Que Exec: True, menu.skin, "ONSTART", False
09:02:34.863: Que Exec: True, menu.skin, "ONLINE", False
09:02:34.873: Que Exec: True, menu.skin, "ONSKINSTART", False
09:02:34.873: Que Exec: True, menu.skin, "ONPLAYERREADY", False
09:02:34.873: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
09:02:34.885: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
09:02:38.623: Enter Exec: False, menu.skin, "ONBTNPRESS||RRDROID", False
09:02:38.623: Que Exec: True, menu.skin, "ONBTNPRESS||RRDROID", False
09:02:38.623: Que Exec: True, menu.skin, "RRDROID", False
09:02:38.623: EXECTBL Translation: RRDROID -> ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
09:02:38.635: Executing: ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
09:02:38.635: Que Exec: True, menu.skin, "RRDroidCL", False
09:02:38.635: EXECTBL Translation: RRDroidCL -> Load;rrdroid_CL.skin
09:02:38.635: Executing: Load;rrdroid_CL.skin
09:02:39.193: Que Exec: True, rrdroid_cl.skin, "ONSCREENCHANGE", False
09:02:39.193: Leave Exec: False, rrdroid_cl.skin, ONSCREENCHANGE, False
09:03:37.514: Enter Exec: False, rrdroid_cl.skin, "ONBTNPRESS||EXIT", False
09:03:37.514: Que Exec: True, rrdroid_cl.skin, "ONBTNPRESS||EXIT", False
09:03:37.514: Que Exec: True, rrdroid_cl.skin, "EXIT", False
09:03:37.523: Executing: EXIT
09:03:37.545: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
09:03:37.545: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
09:03:38.574: Enter Exec: False, menu.skin, "ONBTNPRESS||ESC", False
09:03:38.574: Que Exec: True, menu.skin, "ONBTNPRESS||ESC", False
09:03:38.574: Que Exec: True, menu.skin, "ESC", False
09:03:38.584: Executing: ESC
09:03:38.584: Enter Exec: False, menu.skin, "ONEXIT", False
09:03:38.584: Que Exec: True, menu.skin, "ONEXIT", False
09:03:38.584: Leave Exec: False, menu.skin, ONEXIT, False
09:03:38.584: Shutdown: (1)
09:03:38.584: Shutdown: (2)
09:03:38.594: Shutdown: (3)
09:03:38.594: Shutdown: (4)
09:03:38.594: INFO: SaveResume() - Saving resume data to C:\Users\Dragon\Documents\RideRunner\Cache\resume.ini
09:03:38.594: INFO: LoadResume() - Reading resume data from C:\Users\Dragon\Documents\RideRunner\Cache\resume.ini
09:03:38.594: Plugin Manager: Warning Plugin mappoint does not support Terminate Method
09:03:38.623: Plugin Manager: Warning Plugin skintool does not support Terminate Method
09:03:38.623: Plugin Manager: Warning Plugin weather does not support Terminate Method
09:03:38.623: Plugin Manager: ALL Plugins unloaded.
09:03:38.764: Shutdown: (5)
09:03:38.764: Player is running
09:03:39.074: Shutdown: (6)
09:03:39.074: Shutdown: (7)
09:03:39.074: OSUnloadMode: 1
09:03:39.074: Global Hotkey: All keys unregistered
Will this plugin mute and resume playing music on the PC?
