Page 10 of 15 FirstFirst 123456789101112131415 LastLast
Results 91 to 100 of 145
Like Tree2Likes
Thread: RRDroid [phone control for Android phones]
  1. #91
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    ok, thanks
    View my worklog here
  2. #92
    Jul 2006
    Hi El Camino,
    I'm working on a skin for Reborn I took it over from Eugeneij because he had some trouble with it.
    I have some trouble with the plugin I cant get it connect to my phone anymore. There was an update of the CC application and i was testing the Password function either one of them seem to have broken my connection. I suspect the update because i cant connect with Bluetooth either.
    I have unregisterd the plugin and reregisterd it.
    I can connect with the CC application without problem with WiFi or BlueTooth without problems. But not with the plugin the phone app keeps waiting for a connection. I tried re´nstalling the older version but it wont let me make a connection because of outdated software.
  3. #93
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by Zanbee View Post
    Hi El Camino,
    i didnt know about the update, i will add some code to overcome this, for now please go to "C:\Program Files\JustPhone\CallCenter" and copy all files to RRDroid folder. this will get you going.
  4. #94
    Jan 2013
    I am trying to get your plugin working with the default carwings skin; I have CallCenter installed and working, I also copied it into the RRDroid directory like you mentioned above. When I click on the RRDroid menu button, nothing happens. I checked the debug log, and this is what I get:
    Code:
    11:21:05.406: Enter Exec: False, menu.skin, "ONBTNPRESS||RRMenuItem;5", False
    11:21:05.406: Que Exec: True, menu.skin, "ONBTNPRESS||RRMenuItem;5", False
    11:21:05.406: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    11:21:05.418: Executing: PlaySound;C:\Users\Dragon\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    11:21:05.418: Que Exec: True, menu.skin, "RRMenuItem;5", False
    11:21:05.418: Executing: RRMenuItem;5
    11:21:05.418: Que Exec: True, menu.skin, "RRDroid", False
    11:21:05.418: Executing: RRDroid
    11:21:05.418: Command not executed: RRDroid
    11:21:05.418: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
    11:21:05.426: Executing: ONCOMMANDINVALID
    11:21:05.426: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
    I also noticed that there is a bluetooth icon at the top right of RideRunner, but I have never seen it light up. Is there a way to enable it, or something I have to configure?
  5. #95
    EL CAMINO's Avatar
    Jul 2005
    Quote Originally Posted by dragon1013 View Post
    Code:
    i dont see if the pi is registered or not, are you using bluetooth or wifi?, last package i did for the pi is including latest version, did you try with the included test skin before adding it to carwings?
  6. #96
    Jan 2013
    Thank you for the reply. Yes the pi is registered, I am using BT I tried it in the test skin and it brought up the phone skin but it was blank and none of the buttons did anything. I have been searching on here and on google for any info regarding the bluetooth icon not lighting up in RR with no luck. I just have a feeling part of my problem lies there. I am just getting started with RR so if this is a dumb question im very sorry.
  7. #97
    EL CAMINO's Avatar
    Jul 2005
    please give more details OS, .net installed, bt stack, and post a clean full debuglog, this will help a little more, , did you read the readme? lists the minimum requirements.
  8. #98
    Jan 2013
    Tonight I uninstalled everything and started fresh with a new install of riderunner. I then went step by step through the readme. Still had the same results launch RR with test skin I can get to the phone skin/page but there is no BT connection and nothing in the contacts pane. Here are the details of my install. Windows 7 32bit, .NET 4.5, intel BT Stack. Here is the complete debug from this attempt.
    Code:
    01/19:
    08:04:39.297: Start -- Version: 1/1/2013
    08:04:39.297: OS Type: Windows 7
    08:04:39.297: FileManager: FileMode = Profile
    08:04:39.297: FileManager: mypath = C:\Program Files\RideRunner\
    08:04:39.297: FileManager: ProfilePath = C:\Users\Dragon\Documents\RideRunner\
    08:04:39.381: Start Sequence: Starting Player...
    08:04:39.381: PLAYER: Initialization creating object
    08:04:39.389: PLAYER: Started
    08:04:39.389: PLAYER: Winamp Version:
    08:04:39.389: PLAYER: Initialization complete
    08:04:39.389: Start Sequence: Starting Radio Device...
    08:04:39.389: Start Sequence: Starting Serial Devices...
    08:04:39.389: Start Sequence: Starting Mixer...
    08:04:39.559: VMC---> Set object successful
    08:04:39.598: Start Sequence: Starting Speech...
    08:04:40.559: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    08:04:40.559: Plugin Manager: loading Global Plugins...
    08:04:40.568: Plugin Manager: Plugin Found: Mappoint
    08:04:40.568: Plugin Manager: Plugin loaded (Global): Mappoint
    08:04:41.037: Plugin Manager: Plugin Found: RRDroid(.NET)
    08:04:41.037: Plugin Manager: Plugin loaded (Global): RRDroid
    08:04:41.059: Plugin Manager: Plugin Found: SkinTool
    08:04:41.059: Plugin Manager: Plugin loaded (Global): SkinTool
    08:04:41.059: Plugin Manager: Plugin Found: Weather
    08:04:41.059: Plugin Manager: Plugin loaded (Global): Weather
    08:04:41.088: Plugin Manager: loading Global Plugins Completed.
    08:04:41.088: LoadSkin: C:\Users\Dragon\Documents\RideRunner\Skins\RRDroid Test Skin\
    08:04:41.098: Plugin Manager: loading SkinDir Plugins...
    08:04:41.098: Plugin Manager: loading SkinDir Plugins Completed.
    08:04:41.518: Global Hotkey: Successfully registered keycode:2112
    08:04:41.559: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
    08:04:41.578: Enter Exec: False, menu.skin, , False
    08:04:41.578: Que Exec: True, menu.skin, "ONSTART", False
    08:04:41.607: Que Exec: True, menu.skin, "ONLINE", False
    08:04:41.607: Que Exec: True, menu.skin, "ONSKINSTART", False
    08:04:41.607: Que Exec: True, menu.skin, "ONPLAYERREADY", False
    08:04:41.607: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    08:04:41.617: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    08:04:45.607: Enter Exec: False, menu.skin, "ONBTNPRESS||RRDROID", False
    08:04:45.607: Que Exec: True, menu.skin, "ONBTNPRESS||RRDROID", False
    08:04:45.607: Que Exec: True, menu.skin, "RRDROID", False
    08:04:45.607: EXECTBL Translation: RRDROID -> ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
    08:04:45.617: Executing: ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
    08:04:45.617: Que Exec: True, menu.skin, "RRDroidCL", False
    08:04:45.617: EXECTBL Translation: RRDroidCL -> Load;rrdroid_CL.skin
    08:04:45.617: Executing: Load;rrdroid_CL.skin
    08:04:46.148: Que Exec: True, rrdroid_cl.skin, "ONSCREENCHANGE", False
    08:04:46.148: Leave Exec: False, rrdroid_cl.skin, ONSCREENCHANGE, False
    Thank You!
  9. #99
    Jan 2013
    I just noticed on my phone when I start RR my phone goes from connected to bluetooth client to waiting for for bluetooth client. Here is another log it shows more than the last one.
    Code:
    01/19:
    09:02:31.566: Start -- Version: 1/1/2013
    09:02:31.566: OS Type: Windows 7
    09:02:31.566: FileManager: FileMode = Profile
    09:02:31.566: FileManager: mypath = C:\Program Files\RideRunner\
    09:02:31.566: FileManager: ProfilePath = C:\Users\Dragon\Documents\RideRunner\
    09:02:31.646: Start Sequence: Starting Player...
    09:02:31.646: PLAYER: Initialization creating object
    09:02:32.057: PLAYER: Started
    09:02:32.176: PLAYER: Winamp Version: 5.63
    09:02:32.227: PLAYER: Initialization complete
    09:02:32.227: Start Sequence: Starting Radio Device...
    09:02:32.227: Start Sequence: Starting Serial Devices...
    09:02:32.227: Start Sequence: Starting Mixer...
    09:02:32.387: VMC---> Set object successful
    09:02:32.406: Start Sequence: Starting Speech...
    09:02:33.580: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    09:02:33.580: Plugin Manager: loading Global Plugins...
    09:02:33.590: Plugin Manager: Plugin Found: Mappoint
    09:02:33.590: Plugin Manager: Plugin loaded (Global): Mappoint
    09:02:34.154: Plugin Manager: Plugin Found: RRDroid(.NET)
    09:02:34.154: Plugin Manager: Plugin loaded (Global): RRDroid
    09:02:34.174: Plugin Manager: Plugin Found: SkinTool
    09:02:34.174: Plugin Manager: Plugin loaded (Global): SkinTool
    09:02:34.184: Plugin Manager: Plugin Found: Weather
    09:02:34.184: Plugin Manager: Plugin loaded (Global): Weather
    09:02:34.203: Plugin Manager: loading Global Plugins Completed.
    09:02:34.203: LoadSkin: C:\Users\Dragon\Documents\RideRunner\Skins\RRDroid Test Skin\
    09:02:34.225: Plugin Manager: loading SkinDir Plugins...
    09:02:34.225: Plugin Manager: loading SkinDir Plugins Completed.
    09:02:34.734: Global Hotkey: Successfully registered keycode:2112
    09:02:34.805: PLAYER: Restored rrpl.m3u8
    09:02:34.805: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
    09:02:34.805: INFO: LoadResume() - Reading resume data from C:\Users\Dragon\Documents\RideRunner\Cache\resume.ini
    09:02:34.824: Enter Exec: False, menu.skin, , False
    09:02:34.824: Que Exec: True, menu.skin, "ONSTART", False
    09:02:34.863: Que Exec: True, menu.skin, "ONLINE", False
    09:02:34.873: Que Exec: True, menu.skin, "ONSKINSTART", False
    09:02:34.873: Que Exec: True, menu.skin, "ONPLAYERREADY", False
    09:02:34.873: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    09:02:34.885: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    09:02:38.623: Enter Exec: False, menu.skin, "ONBTNPRESS||RRDROID", False
    09:02:38.623: Que Exec: True, menu.skin, "ONBTNPRESS||RRDROID", False
    09:02:38.623: Que Exec: True, menu.skin, "RRDROID", False
    09:02:38.623: EXECTBL Translation: RRDROID -> ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
    09:02:38.635: Executing: ByVar;RRDroid_UseXML;RRDroidCL<<RRDroidXML
    09:02:38.635: Que Exec: True, menu.skin, "RRDroidCL", False
    09:02:38.635: EXECTBL Translation: RRDroidCL -> Load;rrdroid_CL.skin
    09:02:38.635: Executing: Load;rrdroid_CL.skin
    09:02:39.193: Que Exec: True, rrdroid_cl.skin, "ONSCREENCHANGE", False
    09:02:39.193: Leave Exec: False, rrdroid_cl.skin, ONSCREENCHANGE, False
    09:03:37.514: Enter Exec: False, rrdroid_cl.skin, "ONBTNPRESS||EXIT", False
    09:03:37.514: Que Exec: True, rrdroid_cl.skin, "ONBTNPRESS||EXIT", False
    09:03:37.514: Que Exec: True, rrdroid_cl.skin, "EXIT", False
    09:03:37.523: Executing: EXIT
    09:03:37.545: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    09:03:37.545: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    09:03:38.574: Enter Exec: False, menu.skin, "ONBTNPRESS||ESC", False
    09:03:38.574: Que Exec: True, menu.skin, "ONBTNPRESS||ESC", False
    09:03:38.574: Que Exec: True, menu.skin, "ESC", False
    09:03:38.584: Executing: ESC
    09:03:38.584: Enter Exec: False, menu.skin, "ONEXIT", False
    09:03:38.584: Que Exec: True, menu.skin, "ONEXIT", False
    09:03:38.584: Leave Exec: False, menu.skin, ONEXIT, False
    09:03:38.584: Shutdown: (1)
    09:03:38.584: Shutdown: (2)
    09:03:38.594: Shutdown: (3)
    09:03:38.594: Shutdown: (4)
    09:03:38.594: INFO: SaveResume() - Saving resume data to C:\Users\Dragon\Documents\RideRunner\Cache\resume.ini
    09:03:38.594: INFO: LoadResume() - Reading resume data from C:\Users\Dragon\Documents\RideRunner\Cache\resume.ini
    09:03:38.594: Plugin Manager: Warning Plugin mappoint does not support Terminate Method
    09:03:38.623: Plugin Manager: Warning Plugin skintool does not support Terminate Method
    09:03:38.623: Plugin Manager: Warning Plugin weather does not support Terminate Method
    09:03:38.623: Plugin Manager: ALL Plugins unloaded.
    09:03:38.764: Shutdown: (5)
    09:03:38.764: Player is running
    09:03:39.074: Shutdown: (6)
    09:03:39.074: Shutdown: (7)
    09:03:39.074: OSUnloadMode: 1
    09:03:39.074: Global Hotkey: All keys unregistered
  10. #100
    Feb 2011
    Will this plugin mute and resume playing music on the PC?
  1. Android Frontend App for tablets and phones
    By NightJumper in forum Android Tablet
    Last Post: 05-15-2013, 02:04 PM
  2. Android phone control
    By lorenzo90 in forum Software & Software Development
    Last Post: 11-12-2012, 01:40 PM
  3. Real VNC Automotive Remote Control to Android Phone?
    By kelbury in forum General MP3Car Discussion
    Last Post: 06-24-2012, 11:40 AM
  4. Android Tablet / Phone in car
    By mchipser in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-19-2011, 01:21 PM
  5. Phone integration with CDMA phones?
    By stonestatue in forum Road Runner
    Last Post: 05-01-2008, 08:53 PM
