ok, heres another dll to try, changed some settings in VS.
UNREGISTER FIRST THEN COPY NEW DLL AND REGISTER AGAIN.
@pierrot, if CallCenter works on xp pi will do as well, just be sure to have .NET 4, cant use .NET 3.5 CallCenter needs 4.
I have tried it on XP Pro SP2 (in the car), XP Pro SP3 (home PC), Win 7 Pro 32 bit (in the office) it says it is registered in all cases but RR will not load the plugin.
I have .NET 2.0, 3.5 & 4.0 installed on each machine but I do not think that's a problem. Any inputs are welcome.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
so, did you tried the other DLL? Please check if Callcenter works first then try the pi.
Callcenter works both on XP and Win7, at least on my machines. Have tried the other DLL both on Win7 Pro and XP Pro SP2 in the car. I am still getting the same message in RR debug, i.e. "Plugin Found: RRDroid(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped]" although it is registered.
What is interesting is that when the pi is registered, RR crashes upon resume from hibernation but does not crash upon resume from suspend. When it is not registered it does not.
Which RR version are you using El? I am using the latest. Could it be a bug in RR?
im using latest RR version to test, one thing that might be the issue is, the apk i got to test app is not taken from playstore, im getting it from the author so im not sure if is the same, what you can do is copy all files from "C:\Program Files\JustPhone\CallCenter" into the pi folder, and try. please let me know...
Ok, the .apk I am using is Rev. 5, so should be the latest as it is also quoted as such in the Playstore. I copied all files from "C:\Program Files\JustPhone\CallCenter" intothe pi folder ("C:\Program Files\Riderunner\Plugins\RRDroid") an d I am still getting the same messsage in debug, i.e. "Plugin Found: RRDroid(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped]".
I tried it also by unregistering and re-registering RRDroid.dll but with no success. When I copied the files in the pi folder I noticed that "RemotePhoneClient.dll" and "RemotePhoneDataObjects.dll" in the pi were larger in size than the ones in the CallCenter folder (116 & 126 KB vs 80 & 93 KB respectively). I tried the pi using both the larger and smalller files but still got the same message in debug as above.
Something is preventing the pi from loading but what?
this lets us with 2 things not related to callcenter, speech recognition, and mp3 player for ringtones which is based on winmm.dll,part of windows, PM me youre email to send you my apk and please send me the apk you have, cant test the latest trial on my phone. i have another dll with some more twakes and add ons to both pi and skin(same link from my dropbox), i even tried the pi on w8 and does work.
I try this new dll on my XP SP3 without Callcenter installed on my PC and now i see well RRDroid into the Plugin Manager!
Just one thing, that would be cool to add thes lines into your plugin please !
?Code:Case "menuitem" Properties = Chr(34) + "RRDroid" + Chr(34) + ",RRDroid,Icons\RRDroid.png,RRDroid,RRDroid is selected"
Does exit a direct link to install CallCenter on my PC without use the normal method (send by wifi or bluethooth) ?
