Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 107
Like Tree1Likes
Thread: RRDroid [phone control for Android phones]
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by EL CAMINO View Post
    ok, heres another dll to try, changed some settings in VS.
    UNREGISTER FIRST THEN COPY NEW DLL AND REGISTER AGAIN.
    @pierrot, if CallCenter works on xp pi will do as well, just be sure to have .NET 4, cant use .NET 3.5 CallCenter needs 4.
    I have well the framework 4.0 installed on my xp and i think that this run on XP sp3 for me , but i don't know how to install call center on my pc !
  2. #22
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by pierrotm777 View Post
    I try this new dll on my XP SP3 without Callcenter installed on my PC and now i see well RRDroid into the Plugin Manager!
    Just one thing, that would be cool to add thes lines into your plugin please !
    Code:
               Case "menuitem"
                    Properties = Chr(34) + "RRDroid" + Chr(34) + ",RRDroid,Icons\RRDroid.png,RRDroid,RRDroid is selected"
    whats this for?
    and the best way to install CallCenter is using the phone app, there is a workaround, but why you dont want to use send button? wont harm nothing. to get to the msi installer without sending it from phone takes more steps, and is the same result, you need to backup the phone app, when you got the apk open it with winrar, res->raw youll find the msi inside a zip.
    are you trying with wifi or bt, for bt you may not need callcenter, for wifi you need callcenter for first setup, i say is better to have callcenter to make sure phone does connect to pc.
  3. #23
    May 2008
    Bordeaux, France
    This plugin is an amazing plugin !!!
    I can say than it's run very well on BT on my XP SP3.
    I have installed in fact by the first setup method !!!
    Wonderful, i have just tested the call option . I can see all my contacts list !!!!
    The lines that follow are for the Dynamics Menu option (add these lines into your properties function into your plugin)
    Case "menuitem"
    and if you can to add the setting command into the function that follow:
    '* This sub is called when pluginmgr;settings command is used
    Public Sub Settings(ByRef frm As Object)
    SDK.Execute("Menu;rrdroid_config.skin")
    End Sub
    EL CAMINO's Avatar
    Jul 2005
    glad is working for you, i will add the properties code, as you are suggesting, i need to understand how this dynamic menus work, is new stuff to me.
    about the settings sub code,i did add an event, because some skinners use MENU others can go with LOAD, have a look to the skinCMD txt all is there.
    the skin is a test skin just to show some way of skin it, also i even included some flash movies.
  5. #25
    May 2008
    Bordeaux, France
    About the dynamics menu, read this thread !!!
    You can also just add into the menu.lst file this line !
    RRDROID = "RRDROID",DROID PHONE,Icons\PHONE.png,,Droid Phone is selected
    This line isn't needed if the properties menuitem exist into your plugin !!!
  6. #26
    EL CAMINO's Avatar
    Jul 2005
    i have added what you requested. thanks for the info.
  7. #27
    May 2008
    Bordeaux, France
    Cool, thanks
    Is it possible to have an indicator for the signal's power and the type of frequency( gprs,edge,3g,3g+,H+,4g ) ?
  8. #28
    May 2008
    Bordeaux, France
    That would be a cool idea to have an access to the settings into the plugin manager !
    End Sub
    I send you my skin files, if you need, for this plugin (Dynamics menus)!
    Attached Files Attached Files
  9. #29
    Apr 2007
    Well, I have tried the .apk El send me. Now the RemotePhoneClient.dll, etc. version in both CallCenter and his pi are the same but unfortunately I am still gettting the same error in RR debug as before about the plugin not being registered although it seems to register as RRDroid.tlb is created.
    I really do not know what to else search for. Any suggestions are welcome.
  10. #30
    EL CAMINO's Avatar
    Jul 2005
    if the tlb file is created means the pi is registered, be sure to get the latest package as im updating it constantly, i've added the dynamic menus code pierrot told me, improved the speed a little more, and fixed a few bugs.
    in all your systems you get the same issue?, try to disable UAC or run RR as administrator, this is needed on W8, i even had to set regasm.exe to "run as administrator" when registering PI, one thing is, try to use microsoft stack. is youre BT dongle connected directly to youre PC, not in a USB HUB, this may be the cause of youre hibernation issues, try to use wifi instead of BT, disconnect youre BT dongle, or disable it if is built in in youre system. pi can use either one, BT or wifi. for wifi to work, first connect with CallCenter gui.
  1. Android Frontend App for tablets and phones
    By NightJumper in forum Android Tablet
    Last Post: 05-15-2013, 01:04 PM
  2. Android phone control
    By lorenzo90 in forum Software & Software Development
    Last Post: 11-12-2012, 12:40 PM
  3. Real VNC Automotive Remote Control to Android Phone?
    By kelbury in forum General MP3Car Discussion
    Last Post: 06-24-2012, 10:40 AM
  4. Android Tablet / Phone in car
    By mchipser in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-19-2011, 12:21 PM
  5. Phone integration with CDMA phones?
    By stonestatue in forum Road Runner
    Last Post: 05-01-2008, 07:53 PM
