Thanks for your fast response :).
Printable View
Hello Beezer,
Still not clear to me on installation.
Where do i need to put the
GATSO Hunter_RR_v0.3b.exe --> in a directory called e.g. GATSO_Hunter_RR below my program files directory ?
where to put the GATSO Hunter.ini and the cvs file ?
How do I start it up : before starting RR ? Or does it start togetter with RR ?
Sorry but can't find to lett it run.
You should include the answers in the file instructions.txt
txs.
Great App. Seems to work well with my GPS Simulator on the desktop, will try it "Live" over the next few days.
Is there a way to make RRGH run minimised and perhaps as an icon in the tray bar ? When started it seems to be over the top of my RR until i click on RR as being the main focused application.
I have even made the pop-up warning to compliment the Simplistique Skin.
Thanks for that, didn't think of the shortcut minimised option.
Has anyone has this voice announcement duplicated ? More often than not, it will announce twice, but with about half a second delay between the announcements, so it kind of sounds like an echo echo !!
Any ideas ?
Great plugin, Thanks to all
Cant see anything in the readme, but does this require freedrive to work properley?
im using Pc Navigator 7 at the mo
Cheers
It does not need freedrive, just needs RR running to get the GPS cords I believe (can't remember if it can get them direct or not).
useing this for awhile now.
the idea is that you start GH and that start RR, providing you have gps port in the rr.ini all should work ok
