Page 14 of 19 FirstFirst ... 45678910111213141516171819 LastLast
Results 131 to 140 of 181
Thread: GatsoHunterRR
  1. #131
    Constant Bitrate C4DAO's Avatar
    Apr 2007
    Cardiff
    Thank you will check this out.
    Can I also ask - are there are plans to expand on this program? Having had a conversation with Nomader, I'd love to see this program expanded to be able to deal with POIs. Unfortunately I understand D6 (my GPS of choice) cannot communicate with RR and this won't change until a release of the SDK, but it may be possible to download files of POIs, and then import them into RRGatso? Just as a camera alert pops up when you approach a camera I'd love for a similar alert for a POI. If you could configure what alerts could pop up and when this would be fantastic! The only problem I see is how the program would distinguish between different POIs?
  2. #132
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i think you can do this
    Quote Originally Posted by C4DAO View Post
    in d6 as well , you need POIEditor (google) This covert the most files into d6 .dat files so they can be read in d6.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #133
    Apr 2007
    Cardiff
    Thanks for the reply. However your message confused me slightly. I'm looking to specifically import the POIs into RRGatso as I like it's ability to pop up a warning (or in my idea a notification) message and icon on the main screen - however because I believe RRGatso deals only with Gatso's is there any way to make it determine between different POIs, and flash up an appropriate message and icon?
  4. #134
    Dec 2006
    Belgium, Lokeren
    Hello all,
    2th try :
    Still not clear to me on installation.
    I did what was written in the installation txt.
    Where do i need to put the
    GATSO Hunter_RR_v0.3b.exe --> in a directory called e.g. GATSO_Hunter_RR below my program files directory ? In the RR main directory ? In my skin directory ?
    where to put the GATSO Hunter.ini and the .cvs file ?
    How do I start it up : before starting RR ? Or does it start togetter with RR ?
    Can I run the GATSO Hunter_RR_v0.3b.exe without having running RR (for testing) ?
    Do I need to change skin files in my existing skin ?
    How do I see it is running ?
    Sorry but can't find to let it run.
    thanks
  5. #135
    Dec 2006
    Belgium, Lokeren
    GHRR dead ?
    Isn't anyone using any more GHRR ?
    No more posts on this topic since a year ?
    Maybe it is working for all of you but it seems not to work for me.
    Simple question : when you add a cam to the database (with the ADD CAM buttom), are the coordinates writen with a dot (.) or with a colum (,) ?
    Mines are with a (,) and seems not to work.
  6. #136
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I suspect this has been written with the UK/US way of representing decimal numbers ie with the use of .'s
    As opposed to the European way with ,'s
  7. #137
    Newbie acittlau's Avatar
    Sep 2005
    Norway
    I am absolutely still using it. Great little software.
    I am guessing that your dot/comma situation is related to what is set under regional settings in windows. Non-english settings often use comma as decimal symbol. Change it to dot instead.
  8. #138
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    For those who having probs with rapid share
    heres the same files from beezers 1st post
    voices in prev posts
    Attached Files Attached Files
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  9. #139
    Nov 2006
    Wales, UK
    Quote Originally Posted by carputer1;1145453[B
    ]"GHRRCAMALERT","GPS;camalert.skin"[/B]
    put the last change back the way it was
    "GHRRCAMALERT","",external_gps.skin
    not sure if this will work as i don't use the pop up, it got annoying,
    Thanks for the quick reply - I have:
    Replacing with your code:
    "GHRRCAMALERT","external_gps.skin"
    the alert doesn't come up in either the menu skin or the GPS skin?
    Im having the same prob...
    Works fine, voice alerts and beeps, but i dont get the warning skin showing (have all the setting are per the readme file)
    Did this solve it?
    CarPuter Progress:
  10. #140
