Page 15 of 19 FirstFirst ... 5678910111213141516171819 LastLast
Results 141 to 150 of 181
Thread: GatsoHunterRR
  1. #141
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    This in your exectbl.ini should allow it to pop up in any screen
    "GHRCAMALERT","MENU;camalert.skin"
    Cheers E, i believe thats already there tho
    ExecTBL.ini
    Code:
    "GHRRCAMALERT","",external_gps.skin
    "GHRRCAMALERT","",camalert.skin
    "GHRRCAMALERT","MENU;camalert.skin"
    "GHRRCAMALERTCANCEL","EXIT",camalert.skin
    "GHRRCAMALERTCANCEL"," "
    All the skins are copied into the skin im using...
    Does everything look right? im using it from the GPS screen (PC-Navigator)
    Cheers
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #142
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well that's the command (less GHR) that my freedrive uses and it works fine.
    here's a clip from my exectbl.ini
    Code:
    "CAMALERT","",external_gps.skin
    "CAMALERT","MENU;camalert.skin"
    "CAMALERTCANCEL","exit",camalert.skin
    Turn on RR debuging and post a debug.txt file.
  3. #143
    Nov 2006
    Wales, UK
    :E,
    It came up ok on MENU.skin, but not on the GPS (Its using External gps skin), maybe its the nav program thats causing it...
    Do you happen to know if this software is capeable of playing different wavs for redlight & mobile cameras I believe you have this functionality in your freedrive version
    Cheers
    CarPuter Progress:
  4. #144
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, let me explain what these lines in your Exectbl.ini will do. Then it should become clear.
    The red will indicate what happens upon receiving GHRRCAMALERT
    Am I in external_gps.skin? if yes do what is in quotes (ie nothing)
    Am I in camalert.skin? if yes do what is in quotes (ie nothing, this is because you don't want another alert to be triggered when you are already in the alert skin.
    No specific skin so do what it says in quotes. (ie pop the alert skin up)
    So basically remove the external_gps.skin line and it should pop up the alert in the external_gps.skin.
    The reason I have the blank external_gps one in my exectbl.ini is because I have freedrive running in it and that pops up it's internal screen.
    As for the different sounds I have no idea, sorry.
  5. #145
    Nov 2006
    Wales, UK
    Cheers E
    That makes sense, il make the changes and see if it works
    As for the other probs il PM Beezer, this project seems to be on hold for the moment...
    CarPuter Progress:
  6. #146
    Dec 2007
    Is this great toy pretty much for European guys? Can i use this in the U.S.?
  7. #147
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you should
    Quote Originally Posted by brandensin View Post
    be able to as long as you have a list of cams in .csv format ,just drop them into the ghrr folder and away you go . i have been using this here the same side of the water as E and its pretty much spot on
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  8. #148
    Dec 2007
    cool.. carputer1.. help me out a little.. do you or anyone know where i can find this list?
    I thought i just ask before i do some research on the net... I read the whole thread, i failed to find any info for the U.S.
    ok.. i did some search... looks like this is mainly for UK dudes..... cuz, i just can't find anyone from the U.S. wanting or even interested in getting this database other than UK dudes and other european guys...
    http://www.pocketgpsworld.com/module...viewforum&f=20
    So, i guess this toy is not for me...
  9. #149
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    thats where i got mine from
    give me a tic trying somthing may find somthing where i'm looking
    edit i think i have somthing just found a usa speedcamera.txt file DL now and will let you know.
  10. #150
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well i have
    the US camra's now ,but its layed out differently, i think the file i have is for ig, i think can't be sure. so it needs to be redone so ghrr can read it.
    i have added the file to this thread
    you should have an old uk version with ghrr to see the difference.
    Attached Files Attached Files
