Thanks carputer... I appreciate it.. IG is what i have... so, this camera warning thing is builit into IG? Sounds like IG's been hacked or the functionality is already there...
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
Hi,
Can we compare ini's?
Went on a run today, and for some reason it goes off over every speed camera, ones that arnt on my side of the road, and cameras that were no where near my direction of travel ie red light camera (which was on another junction, along way away!
heres mine:
Also a camera alert goes off, it pauses winamp, but doesnt unpause it afterwards (it does this inconsistently ie 1 in 3 cameras)Code:[GATSO Hunter] [Main] CLOSEZONE=15 WARNZONE=0.2 HEADINGTOLERANCE=45 CAMERAFILE=pocketgps_uk_sc.csv SPEEDUNIT=mph WARNATLOWSPEED=False # Possible values for WARNGPSNOTLOCKED are - False/Once/Always WARNGPSNOTLOCKED=Once # Interval for warning if you are using 'Always' warn WARNGPSNOTLOCKEDINTERVAL=10 # Possible values for WINAMPMUTE are - False/Pause/Absolute/Relative WINAMPMUTE=Pause # WINAMPRELATIVE is 0-64 and measures how many units to take volume down by. WINAMPRELATIVE=32
i have also added a label for the next camera distance, which works but is displayed in kmh as opposed to mph as ive set in the ini
Cheers
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
get other side of the road cameras, i do i even drop the closezone range right down and still get it , as for the others i sometimes get the same drop you closezone setting will stop some of them
Will have to a feature request when Beezer gets back into it, im sure theres a way of alerting only if the camera is in your direction of travel... my last drive it was going off every 2 mins with an alert, and 70% of it wasnt even in my direction of travel!![]()
CarPuter Progress:
near me then (London) shed load's of cameras round here lol...
It's tricky as cameras aren't always placed on a dead straight road.
Freedrive has the option on indicating which direction it is and also looks to see if you are on the same road. Unfortuantely it still can be hit or miss, and sometimes the cameras won't show up on your side.
I'd rather be warned of cameras on the wrong side that not warned of cameras on my side.
Good point
When i use my tom tom with the speed camera alerts its 100% accurate with everything including the direction of the camera
CarPuter Progress:
I've compiled yesterday a Canadian/USA redlight/speedtrap database from these two databases for use with GatsoHunterRR.
http://www.phantomalert.com/gpsapp/p...e/download.php
http://www.gpspassion.com/forumsen/t...TOPIC_ID=61154
Over 6000 entries. Note there may be some duplicates from these two databases, but I don't have the time to remove them manually.
Great program! Whenever I resume from hibernate, I get a voice alert "warning GPS not locked". Anyway to add a couple second delay to possibly avoid hearing this message?? My GPS takes a few seconds to come online after hibernate.
very nice .. blackStealth... Thank you for sharing..
