Page 5 of 19 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 181
Thread: GatsoHunterRR
  1. #41
    Feb 2007
    Croydon UK
    thank you beezer
    i can't wait, lol...
    if you would like further testing i'll be glad to help,
    i can only test not make any program changes.
    look forward to sunday again thanks
  2. #42
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Beezer View Post
    I've already done this
    I gave the latest release to someone to beta test for me but he hasn't got back to me with any results. Seems he only wanted to get his hands on the latest copy without giving anything back.
    I'll try it out myself this weekend and provided it works fine, I'll do a public beta on Sunday.
    ey... see this thread and maybe u'll understand why I havn't been able to give u any hints... http://www.mp3car.com/vbulletin/lcd-...wont-turn.html
    yup, my screen is broken so I've been without my carpc almost since u sent the beta to me... just wanted to get the facts out...
    Swedish site for CarPC's
    http://www.bilpc.info
  3. #43
    Feb 2007
    Croydon UK
    shame about your screen
    i know what a bummer that can be.
    good luck on sorting it out.
  4. #44
    Constant Bitrate Beezer's Avatar
    Oct 2006
    I've been busy all weekend & not had a chance to test this any further, but I'll keep to my promise & release an alpha for you guys to try. I'd like feedback on this please.
    http://213.170.0.151:8080/~ian/gatso...r_RR_v0.2b.zip
    For pop up cam alert screen in Road Runner, do the following:-
    1) Add the following to you ExecTBL.ini. This file exists in the RoadRunner home directory. If its not there, create it..
    / GatsoHunterRR Support
    "GHRRCAMALERT","",external_gps.skin
    "GHRRCAMALERT","",camalert.skin
    "GHRRCAMALERT","MENU;camalert.skin"
    "GHRRCAMALERTCANCEL","EXIT",camalert.skin
    "GHRRCAMALERTCANCEL"," "
    2) Copy the contents of the skin directory into the directory containing the skin that you're using
    3) Run GatsoHunterRR.
  5. #45
    Feb 2007
    Croydon UK
    thank you Beezer
    i will try and help as much as i can ,and i'm sure others will input,i'll install in a couple of days
    thanks
    won't run gives me an error like
    activex component can't create object (err no:429 source:GatsohunterRR)
  6. #46
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Hi - heres a suggestion... why not have the prog out put the type of cam & speed to a skin via an SDK like CDR does with RR then it can be a little more intergrated ?
    Just a thought having have 2 pints of the stronges local brew
    Terran
  7. #47
    Oct 2006
    It already does
  8. #48
    Feb 2007
    Croydon UK
    got it running
    today, error was my fault did'nt have rr installed on home comp. silly me
    like the female voice,and i noticed you have to put the com port now.
    anyway all good at the mo.
  9. #49
    Oct 2006
    Yeh you need to follow the instructions in the first post of this thread to get it working with RoadRunner and the GPS
  10. #50
    Feb 2007
    Croydon UK
    success so far
    1st test today ,as i have no cameras to and from work,i made a slight detour,and it warned me of 2 cameras on that route,single warning(great)
    sounds better with the female voice.
    did'nt try the skin as yet,
    took awhile for it to grab sat lock even though i had 7 sat locks before starting GHunter.
    me being dumb, whats the Alert Button for.and the .ini file has a line for com port which the old ver. did'nt,did try quickly deleteing the line so it was the same as old,did'nt get a lock,but i onlt quickly tryed it.i set the com port for another v port not the same as rr.
    just so i know i'm testing right for you what do you need me to look out for.
    again thanks for your effort.
