Page 7 of 19 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 181
Thread: GatsoHunterRR
  1. #61
    Constant Bitrate Beezer's Avatar
    Oct 2006
    Nice work Capri28. I'll fix the runtime error if RR disappears - that's quite easy & then I'll release a beta (rather than an alpha).
    Thx v much for testing.
  2. #62
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Beezer..
    Just so I know I'm right can you list all the possible types of alerts your prog shows & the speeds it shows as well.
    This is so I can create the right art work associated with each type of possible alert.
    Terran
  3. #63
    Oct 2006
    I've already listed them several posts ago.
  4. #64
    Jan 2003
    Quote Originally Posted by Beezer View Post
    Hi, no the lables are but not the possible out puts eg...
    Specs
    Mobile
    Fixed
    then
    10
    20
    70 and so on or does this come directly from the CSV and RRGH just out puts them so it simply reads the vairables and out puts them ?
    Terran
  5. #65
    Oct 2006
    I can check this for you tonight.
  6. #66
    Oct 2006
    Labels:-
    CUSTOMGHRRCLOSEST - closest cam distance in km "x.xx km"
    CUSTOMGHRRCAMTYPE - type of cam (from cam file)
    CUSTOMGHRRCLOSE - number of cams close (integer)
    CUSTOMGHRRWARNING - caption (informational text)
    CUSTOMGHRRSPEEDLIMIT - speed limit (from cam file)
    Triggers:-
    GHRRCAMALERT - event trigger
    Let me know if you want me to set any indicators to make skinning easier.
  7. #67
    Jan 2003
    MMMmm - OK - I have a re think. I was thinking slightly diffently.
    That been said if I can suss out flash skining ( looking in to at the mo ) this may be the best way to get a nice looking skin as such.
    Terran
  8. #68
    Newbie acittlau's Avatar
    Sep 2005
    Norway
    Thank you for your work getting this RR-ified. It's already doing good things.
    I have been testing it a bit the last couple of days, and here is some input. Hope you don't mind.
    1. Is there a chance to get two distance values implemented? First for a early warning like 'approching speed camera' maybe 0.5km before camera, then the existing 'speed camera' alert at 0.2km?
    2. A possibility to warn by audio only if actually speeding?
    3. It seems that relative winamp mute does mute roadrunner instead of winamp. When raising the volume again it also sets it to 100% for some reason.
    4. CUSTOMGHRRSPEEDLIMIT label does include the km text after the numeric value. Is there a way to cut this off? I made a quick camalert.jpg where I put a speedlimit sign, and the label in center of the sign, but doesn't look to smart with the km attached
    5. Clicking the on the pop-up removed it shortly before it re-appeared. It kept doing that a few times before giving up.
  9. #69
    Oct 2006
    Quote Originally Posted by acittlau View Post
    Not at all - the more feedback the better. And don't be afraid to tell me it sucks
    Well, it already has 2 distance values. The first is the voice warning & is configurable in the ini file. The second is the beep noise that sounds when you're near the camera. That's not configurable at present, but I intend to change it to automativally vary its distance based on speed.
    I can probably implement this later on. However, personally I'd like to know about the cameras even if I'm not speeding (not that I ever speed anyway).
    Yes, I noticed that. i'll look in to it. In teh meantime try one of the other options like PAUSE.
    Can do.
    Will investigate. I thought I fixed that in the alpha. Obviously not.
  10. #70
    Oct 2006
    Ok, I've been using this quite a bit myself these days & I've just *GOT* to get it to vary its alerting based on speed. It tells you way too late when you're travelling fast.
    I'll try to get a new release out soon.
