Originally Posted by
laposelemer
Hi!
Some improvements!
1. I found the most useful conbination for me: ver0.4 wireless.exe and wifi_info.exe
but in the exectbl.ini I use the ver 0.3 exectbl content for run.
In this case when I call the wireless skin, the wireless.exe run correctly more or less.
The system hang up about 10-15 sec, after the time the wireless.exe closes itself. And do this only 1 time. If I recall wireless skin it shows the manager correctly.
With the ver0.4 exectbl contents the the system stays hanging. And do this every time I recall the wireless skin.
2. I can reach that to fill out the box:
in exectbl I changed "your" connection name to "my" connection name
"WIRELESS","LOAD;wireless.skin||SETTOPMOST;RR;TRUE ||RUNQW;$SKINPATH$\wireless.exe;My connection name||GETFOCUS"
and I did the same with te button codes.
Still problem:
when I load wireless skin, the wireless.exe calls the "network connections" instead of "reachable wireless network connections" and not the whole system hangs up, only the cursor ?? (it seems the wireless.exe can't close itself or run correctly,because if I shut it down with task manager everything ok) and I have to open manually the "reachable wireless network connections", after this it fill out the box.
Still don't give any info about the connection except speed and type.
I tried this skin on my work laptop, which has builtin wifi and this device has dev.no.
and I have an USB wifi for my car, it hasn't dev.no. hmm...
+1: my hungarian language windows can cause problems to your program to handle the network windows correctly? I mean my window names are translated and this can cause problem?
