Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 41 to 50 of 124
Thread: OLD Wifi Manager - No longer supported
  1. #41
    Hi,
    Any1 had it working with LSXVOID 3.0 pls?
    Also, is there somewhere that explains how to install this? The included readme.TXT file seems to show only updates.
    Jan 2007
    everything's in the readme for custom skinning. You need to go into the skin examples folder with this program and copy the contents of exectbl.ini to your $rrpath$\exectbl.ini
  3. #43
    Sep 2006
    Budapest, Hungary
    Quote Originally Posted by EL CAMINO View Post
    +1 that might be the case, please post a screencap of the next windows,
    "Network Connections" and "Wireless Network Connection" so i can fix that for you.
    (i need to see the window title of each one)
    In the last few days, I do some test.
    So, the wireless.exe (ver.0.45) can run "correctly", but I thing the runtime is too long (1:30 min). After the box will fill correctly. But after the wireless.exe run, my "Network Connections" window will rename to "Wifi information" ??
    problem: Maybe my mismatch "Network Connections" window name can cause the long runtime. I made a screencap about the "Network Connections". That window name in my language is "Hálózati kapcsolatok".
    Here is a picture, you can find my window name.
    I don't know what do you mean in "Wireless Network Connection". Could you explain it?
    Here is an other picture, maybe you can find what you mean.
    The enable/disable feature isn't workable with my wifi USB card (no dev. no.).
    The connection info is now ok.
  4. #44
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    ok, the "wireless Connection Manager" is the window that shows the available networks in range. please do the same, as you did with "Network Connections" window.write down the window title, so i can make a custom wireless.exe for you. i' will upload a new version, that fixes the enable/disable for cards with no dev number.
  5. #45
    Sep 2006
    Budapest, Hungary
    aha...
    the "wireless Connection Manager" window name is the connection name. I can change it as I want. So now my connection name is "RT73 USB Wireless LAN Card". You can see in my last post 2nd picture. Or for example here is another picture from my work laptop.
    I will check the updates.
  6. #46
    EL CAMINO's Avatar
    Jul 2005
    ok, make sure to name that to "Wireless Connection Manager" and try this wireless.exe
    Attached Files Attached Files
  7. #47
    Sep 2006
    Budapest, Hungary
    I renamed my connection to "Wireless Connection Manager" and in the exectbl.ini too.
    And used the attached wireless.exe and the beta 0.6 wifi_man.exe.
    +: the runtime of the wireless.exe is faster than before and don't hang up my mouse,
    -: the wireless.exe don't fill out the box. Only the "connection manager". And rename it to "Wifi information" (i can live with this). I have to open manually the "Wireless Connection Manager". After this everything ok.
    In your readme you advise to delete the "wifiMan.ini".
    Wich file should delete "wifiMan.ini" or "wifi_man.ini"?
    I never had "wifiMan.ini". If I delete "wifi_man.ini" the connection info don't work.
  8. #48
    EL CAMINO's Avatar
    Jul 2005
    wireless.exe is for loading "Wireless Connection Manager" window, take all the stuff out you don't need, resize the window according to what your skin needs. renames the window to "Wifi Information", for some compatibility issues found. thats all,
    about the wifiman.ini, i mean wifi_man.ini(my bad)now wifi_man.exe creates a wifi_man.ini for you, with the right info for your card, if it doesn't work use your old wifi_man.ini and on the dev value enter the full cards id, (for enable/disable feature)
  9. #49
    Sep 2007
    Bit of help if you can
    I can't get wifi_man.exe to run when Road Runner starts using DigitalFX skin
    I have edited ExecTBL under Digitalfx skin using these commands
    I started with:
    "ONSKINSTART","RUN;$SKINPATH$wifi_man.exe"
    nothing..... then I noticed /||RUN;$SkinPath$Scripts\wifi_man.exe
    was already there so i deleted the / but still not loading up wifi_man.exe
    I also tried this ( startcommand=RUN;$SKINPATH$wifi_man.exe") but think it's for another setting page (RR.ini)
    My wifi page would work if I could get it to load wifi_man.exe Any help !!!
    Thanks Paul
  10. #50
    EL CAMINO's Avatar
    Jul 2005
    john has this working in DFX 3.0, ( coming out this month ) i'm beta testing for him and i tell you, the wifi manager has been improved a lot in DFX by john, if you are using 2.5 depending where you have wifi_man.exe, you need to adjust the path, are you getting the wireless skin to load? post some screencaps to see whats going on.
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 07:16 PM
  2. Mercury's Polaris JAN/16/08 No Longer Supported.
    By EL CAMINO in forum RR Skins No Longer Supported
    Last Post: 08-26-2009, 03:08 PM
  3. Quick question about connecting my DIY wifi antenna
    By nobb in forum Wireless Communications
    Last Post: 01-23-2008, 12:23 PM
  4. Ultimate Mobile WiFi Kit ?! my dream !!
    By DJ_MACH7 in forum Wireless Communications
    Last Post: 11-02-2007, 06:30 AM
