Page 7 of 13 FirstFirst 12345678910111213 LastLast
Results 61 to 70 of 124
Thread: OLD Wifi Manager - No longer supported
  1. #61
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    can you give some details about your setup?, skin, RR version, wifi card.
  2. #62
    Nov 2005
    using latest road runner with mc2.0 skin. card in .ini settings says
    [SETTINGS]
    adapter=D-Link DWA-140 RangeBooster N USB Adapter
    dev=USB\VID_07D1&PID_3C09\6&57F755&0&1
    thank you
  3. #63
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Greets,
    Having trouble with the wireless skin.
    Specs:
    WinXP Tablet Edition
    RR Version: 2007/12/13
    DFX3 Skin
    wifi_man.ini:
    [SETTINGS]
    adapter=Hawking HWC54GR Hi-Speed Wireless-G CardBus Card #2
    pause=600
    dev=
    AutoDetect=true
    Stock DFX3 ExecTBL.ini "Button" and "Wireless Network Info by Elcamino" settings
    Stock Wireless.skin
    Here is some screencaps of my issue.
    You will see that the wifi information screen is not resizable
    Takes too long to load and kicks out to menu a couple of times before sometimes loading into clipped area
    Also there is no info updated for the skin
    I can enable and disable the connection
    Any ideas?
    JJG
    As a side note, I have been into this about two weeks and have found everything very easy to figure out and setup, going as far as setting 3 menu screens, embedding my not yet finished OBD app, and changing things to my liking. You just have to read, read, read....I have just ordered a Visteon HD Zoom HDZ300 Radio and the Cable from mitchj.
    Absolutely Awesome RR Front End And DFX3 skin setup. I don't know of guino, but I do know of JohnWPB from the HomeSeer forum. Hats off to you guys and the rest for a sick package.
    ....JJG
  4. #64
    EL CAMINO's Avatar
    Jul 2005
    if you are using DFX3.0 i'm afraid i cant help much, johnWPB made some changes to the scripts to suite his skin better, and i dont have the source to see what was changed from mine, my advice is to ask john. sorry man.
  5. #65
    Newbie gold28's Avatar
    Jan 2008
    Madrid
    Wifi Not Configured
    Quote Originally Posted by Sonicxtacy02 View Post
    i have a question.. is there something in your script that makes road runner exit the wireless.skin file? i ask because i enter the screen... get labels filled in as they are supposed to be and see the box embed.. but maybe 2 seconds later i'm shot back out to menu.skin. In checking the debug.txt for road runner i dont see any command sending me back but it happens every time i use the "WIRELESS" command to open the skin. if i simply do load;wireless.skin manually it doesnt do it. Any idea on what this might be?
    EDIT.. nevermind.. it was because i didnt have the error pop up in my skin file... but i dont understand why there is an error if the labels are populating as they should.
    I am trying to get this working in my skin and am getting the same results as Sonicxtacy. The labels are populated fine but I get this "WIFI NOT CONFIGURED" pop up and the wireless.exe isn't putting the available networks up.
    If I then manually open the available networks via explorer, it posts it where the A, command specifies but the whole window, not just the available networks. All the buttons seem to be working fine and all the lables. It is just posting this popup instead of the available connections window.
    Any ideas what it might be. I have checked all my skin and Exectbl.ini commands numerous times and they seem to be fine.
    Thanks in advance
    Anthony
    Celica GT4 Pilot.
    My Skin Bluetab
  6. #66
    Jan 2008
    Madrid
    Don't worry, it was my wireless network connection window name. For others having some problems, make sure that your window name (see highlighted icon on the second image in post 63 above) is "Wireless Network Connection"
    All works perfectly now, thanks muchly El Camino
    Celica GT4 Pilot.
    My Skin Bluetab
  7. #67
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Nice Work
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  8. #68
    Jun 2007
    Hi, I would like to embed the "Wireless Connection Manager" window into my skin, but (after an intense search...) I can not find the windows executable that launch this program.
    I think that this autoit script open the "Wireless Connection Manager" calling it executable, so, can anyone tell me:
    Whats the cmd command to open the "Wireless Connection Manager"??
    Thanks!
  9. #69
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by jamedinar View Post
    Thanks!
    these are the cmd's in the exetbl top 1in Red launches the skin and sets the script running, the others are different button to use in the skin
    "WIRELESS","LOAD;wireless.skin;WIFI;;WiFi Information||SETTOPMOST;RR;TRUE||RUN;$RRPATH$Plug in's\Wireless\Wireless.exe||SETTOPMOST;RR;FALSE||A CTIVATE;WiFi Information"
    "DISABLE_WIFI","SENDMSG;wifi_man;disable"
    "ENABLE_WIFI","SENDMSG;wifi_man;enable"
    "CONNECT_WIFI","Activate;WiFi Information||SENDKEY;%c"
    "REFRESH_WIFI","Activate;WiFi Information||SENDKEY;{F5}"
    "DISCONNECT_WIFI","Activate;WiFi Information||SENDKEY;%d{ENTER}"
    "PREV_WIFI","Activate;WiFi Information||sendkey;{up}"
    "NEXT_WIFI","Activate;WiFi Information||sendkey;{down}"
    "WirelessLabels","RunQ;$RRPATH$Plug in's\Wireless\wifi_man.exe"
    check out MKIII /DFX /Polaris skin's as i know they have it in there running
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #70
    Jun 2007
    The problem is that I use a spanish windows so this plugin does not works. I think that the problem is that my "Wireless Connection Manager" name is: "Conexiones de red inalámbricas".
    I would like to know the windows .exe that launch this window (I think that must exists one, like taskmgr.exe launch the task manager...)
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 07:16 PM
  2. Mercury's Polaris JAN/16/08 No Longer Supported.
    By EL CAMINO in forum RR Skins No Longer Supported
    Last Post: 08-26-2009, 03:08 PM
  3. Quick question about connecting my DIY wifi antenna
    By nobb in forum Wireless Communications
    Last Post: 01-23-2008, 12:23 PM
  4. Ultimate Mobile WiFi Kit ?! my dream !!
    By DJ_MACH7 in forum Wireless Communications
    Last Post: 11-02-2007, 06:30 AM
