Page 8 of 13 FirstFirst 12345678910111213 LastLast
Results 71 to 80 of 124
Thread: OLD Wifi Manager - No longer supported
  1. #71
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    well is not that easy, "Wireless Connection Manager" is a window not a program, for fixing your issue you can simply rename "Conexiones de red inalámbricas" to "Wireless Connection Manager".try it and you'll see...
  2. #72
    Jun 2007
    Ok, I will try when I go to home. Thanks!!!
    And thanks El Camino, I find so useful your plugins! I hope you continue with the calendar, I would like to have a good one into my skin, and sure it will be...
  3. #73
    Jun 2007
    Hi, I have integrated this script into my skin but I have some problems yet. The problem is with the wireless.exe
    When I launch the wireless.skin and RUNQW the wireless.exe script it begins to open the networks window and next the "Wifi Information" (I renamed it in my spanish Windows ). Everything is fine up to here. Then I can see that the script modifies the "Wifi information" window (hidding the left part...) but then the wireless.exe hangs. All of this process is so slow (is this normal??)
    Then, if I launch the taskManager and kill the wireless.exe process then labels and the "Wifi Information" (embedded) are showed correctly into my skin. All buttons works correctly also.
    So, I have two questions:
    1.- Is this script as slow as I see??
    (25 seconds to open the "Wifi Information")
    2.- Why wireless.exe never ends??
    (I see that the links at the left of the "Wifi Information" window are not hidden completely)
    Could you send me the scripts source to look for some problems with my spanish Window??
    Thanks!!
  4. #74
    EL CAMINO's Avatar
    Jul 2005
    sure, i'll pm you the source for wireless.exe
  5. #75
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Hi guys,
    I've got wifi_man running......well sort of. Is there an info.jpg available as there isn't one in the downloaded 0.6.rar?
    BTW great app. A defo for my setup as I'm just about to put in the wireless adapter.
    Cheers,
    Dave
    Vauxhall Astra SXi Car PC installed.
  6. #76
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Davefocus View Post
    Hi guys,
    Cheers,
    Dave
    Sorry guys,
    I misread the readme a forgot to alter the wireless.skin to change to games_off.jpg,games_off.jpg,games_on.jpg,games_on. jpg.
    I'd still be interested in a BMV2 skin if there's one available!
    Cheers guys (and sorry)
    Dave
  7. #77
    Mar 2005
    Norfolk UK
    OK, here we go. I've had a go at creating my own skin and it's all going well apart from a signal strength indicator bar (just like a mobile phone strength indicator bar) shows the same as the GPS bar.
    I've set it the same as my GPSSIGNAL and VOLUME indicator bars using the code CUSTOM_WIFI_SIGNAL and CUSTOM_WIFI_SIGNAL_DB. They all use the same slider (for now) and the slider code is:
    /, Y, Back Slider file path
    Y01,"\volume_slider\volume_*.jpg"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,640,105,120,40,600,105,120,40,H,01,,,"MASTER",
    S02,430,90,90,20,430,90,90,20,H,01,,,"GPSSIGNAL",
    S03,430,140,90,20,430,140,90,20,H,01,,,"CUSTOM_WIF I_SIGNAL",
    What have I done wrong? I should be ok using same slider bar shouldn'tI?
    Thanks guys,
    Dave
  8. #78
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I suspect that the plugin needs to be updated for the sliders to work.
    Try using a RR version from last year.
    This is a post of mine discussing a similar situation regarding the RRGas plugin.
    RRGAS - Gas prices for the US - Status: Updated 12/01/10
  9. #79
    Mar 2005
    Norfolk UK
    Cheers E,
    I'm using the version dated 13/12/2007 but whether El Camino will have any info regarding this.
    Dave
  10. #80
    Mar 2005
    Norfolk UK
    El Camino,
    Is the CUSTOM_WIFI_SIGNAL affected by using the new version 18/09/08 of RoadRunner or have I put the incorrect code in post 77.
    Nice plugin! I've skinned it apart from the signal stregth bar now .
    Cheers,
    Dave
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 07:16 PM
  2. Mercury's Polaris JAN/16/08 No Longer Supported.
    By EL CAMINO in forum RR Skins No Longer Supported
    Last Post: 08-26-2009, 03:08 PM
  3. Quick question about connecting my DIY wifi antenna
    By nobb in forum Wireless Communications
    Last Post: 01-23-2008, 12:23 PM
  4. Ultimate Mobile WiFi Kit ?! my dream !!
    By DJ_MACH7 in forum Wireless Communications
    Last Post: 11-02-2007, 06:30 AM
