Really, this is way harder than it should be. Especially for newbies. And I'm not a newbie.
If this is referenced in menu.skin as:
along withCode:X,RRStrings
Then the embedded art goes away. I had "ALBUMART" on my menu.skin, and the new variable as an indicator in my Audio_Visuals.skin (whiteroom unreleased skin) and the "ALBUMART" wouldn't display when the X,RRStrings was defined. (Unless you reference the new variable, but sometimes that isn't the same image - compilation albums, or various artists...)Code:X,Mp3Art
I just can't get this right. I've tried so many different combinations, I can't really remember them all, but...
I tried something like this:
So that it does what I was wanting to do in this thread:Code:"TIMER","StrRepl;w_tmp; º F;;mynewtemp",WEATHER.skin
http://www.mp3car.com/vbulletin/road...e-weather.html
with a label for the new variable:
And I get nothing. at all, according to the "instructions" it should replace theCode:LXX,,,,,"$mynewtemp$"
" º F" with "" (basically it will delete the space, degrees symbol, space and the capital 'F' so that all is returned is a normal number that shows the temp, which i want to later have evaluated and made into a slider.)
I have the X,RRStrings extension defined, and even deleted the mp3art definition to make sure it was the only thing being referenced. I'm using the most recent RR beta from the sticky.
Currently the two scripts that Sal R. and MGD helped me with work, perfectly. If it's not easier to use than adding AI scripts, then it won't be used.
So please help clear this up for me and anyone else having this issue.
