FYI, if using a newer RR ver, don't use the "X,xxx" standard to load ext plugins, at some point it will be completely removed.
I'm really suprised that none of the other seasoned RR users caught this, really...
Couple of things:
#1
You can not use a cmd like that in a skin file. Its a cmd to be executed and is why you get no results.
#2
To show a variable in a label you need to use the format "[HL]=[/HL]$xxxx$" (L,356,489,82,54,162,174,11,8,"Arial","=$myvar$"," LEFT")
#3
Also, the only way to do what your trying to do currently would be to correct the improper variable syntax and use a timer to run the strings cmd so that the variable will be constantly updated.
I have now seen enough users that would like some of the standard lables to also be used w/o the descpription part..ie "mp/h,km/h,%" ect and will be creating a way to specify in the label tip, to not add the desc to it. :)
See #1 above.
And using your exact posed code above works, as an executed cmd.
No, it doesn't matter where it's register at.
