I know of it.
But I haven't installed it as I use FreeDrive.
Yes,
All run very well
Do you know GatsoHunter Enforcer ?
Thank
I know of it.
Always on Vista , I have a problem with a font "tahoma not found"
I try to add it on c:\windows\font Freedrive don't see it .
From what I have just read, after doing a little search, it looks like the vista Tahoma font is larger than the XP one.
Anyway I found a thread with a possible solution, it's for MapMonkey but MM uses the same Destinator engine as FreeDrive and it's destinator that is using the font.
Font Tahoma not found
Hi Enforcer,
I had effectively modified Destinator.inf .
I had changed Tahoma font by Arial .
Freedrive will had run just one time and after a bug
it want not run again .
I reboot vista and see again![]()
Enforcer I am trying to put this timer in my skin to replace my flash.exe timer in all my players but while the timer is running the other labels in the skin will not update and it takes a lot of cpu power. I do not know how hard it was to make this but I was thinking if you just made one with hours, minutes and seconds and only update when RR updates other labels it mite let the other labels update and not take so much power.
Would this be possible and easy to do?
Thx chuck
I'll have a look tonight.
OK
Version 1.5
Added ini setting of
short=true
this truncates the displays to just hours, minutes and seconds and only updates the labels as per roadrunner (request of chuck)
Move along for version 1.6 (sorry)
THX Enforcer
I think the old dll file is in the zip file
ops
Try again.
